sourcing door gasket material
RustyShackleford
1,590
NC
I'm having trouble find the correct door gasket material.
I've ordered from this place, which clearly represents themselves as selling BK parts:
...and the material was nowhere near as dense as an old scrap of door gasket (presumably OEM) that I had lying around.
So I tried this:
... which the guy said "is pretty dense". And it's denser than the first place, but still not as dense as the scrap.
The reason I'm trying these options is that there's not really a BK dealer near here.
So, a warning: be very careful about buying gasket material online, at least for door gaskets you're probably not going to get the right stuff.
And a question: is there any good online source for OEM BK gaskets ?
Just called one of the dealers (located using BK's "find a dealer" tool) and they stated "there's no such thing as Blaze King gasket, you just use generic gasket material of the right size". When I corrected them, they were offended.
That's the problem that I've run into, repeatedly, with this previous-century model of everything done thru dealers. Over and over again I'm run into dealers who know jackshit about the product they're supposedly expert on. The above is yet another example.
I wish BK would consider selling parts direct.
Reactions: kborndale and Tron
So I tried this:
Rutland Grapho-Glas Woodstove Gasket Rope, 3/8 by 84-Inch​
I just used some of this - seemed the same as OEM
Reactions: Turbo89
Oh, no foolin' ? Pretty good price on Amazon. Need the 7/8" thickness of course (for Princess door, anyhow).
Ya, I ordered from Amazon. Our Canadian Tire sells it too. I did my P43 pellet stove with it. It was only less than a year old, but I was not happy with the OEM install although the gasket itself seemed the same. I like it better than before. I still have to clean the glass, but the "leak" has disappeared. Sorry I should have said I was referring to my pellet stove, but maybe it's all the same unless it's the one sided tape seal begreen mentioned for the actual glass.
Although, in this thread (posts #242 and 243) : https://www.hearth.com/talk/threads/2022-2023-bk-everything-thread.193316/page-10#post-2605499
... @BKVP pooh-poohs the Rutland material.
I'm sure BKVP knows what he's talking about...but I found when I did it myself, for the first time, there was a huge difference in how you could install it, ie bunched up, semi-bunched, or loose. Each will give you a different inch/inch lay, and density.
I have used these guys in the past for door gasket with no issue
Was it actually labeled "Blaze King", or just good and dense ?
They have this part, which is clearly BK-specific: https://hechlers.com/product/blaze-king-door-latch-catch-0693/
... would like to retrofit, but mine has the welded nut on the inside. I guess it'd be easy to drill out the threads on the welded nut, but then you'd lose 1/4" or so on the 'L'.
Here's yet another tale of someone finding it very difficult to get the right gasket ....
Please PM me the dealer info and we can inform them correctly.
Thanks
BKVP
I had emailed them at the time and they stated oem. It seemed comparable to what I was replacing. It’s still in my door I can attempt some pictures tomorrow if that can be helpful with identification..
Thanks, but i doubt photos will help. I'm tempted to just order it, but it'll be my 4th attempt and it's getting tiresome. (Not everybody is as good with returns as Amazon).
Does BK have a video on the "correct" way to install the gasket? I don't need one now but I'm sure someday I will. Many years ago, I replaced the door gasket on my Old Mill woodstove. If you have never done this, I can tell you that depending on how much tension you place on the rope gasket material you could get maybe for example 30" out of the piece or 50" depending on how tightly you bunch it up or stretch it out.
The gasket should not be bunched or stretched. It should lay in the gasket channel relaxed, without tension.
There's a pretty good verbal description here: https://www.hearth.com/talk/threads/blaze-king-door-gasket-replacement.152827/
Note he suggests building up the spaces (between the studs&nuts that hold the glass in place) with a thick bead of silicon, not mentioned in the instructions in the manual, which I copy below. This of course is because of the curious design decision to have the hardware that holds the window glass in the same channel as where the door gasket fits. This irregularity is probably also why it's so important to get this elusive high-density gasket material.
LOADING DOOR GASKET REPLACEMENT
(Blaze King recommends your dealer perform this task)
1. If the door gasket is to be replaced, be sure you have Blaze King 7/8” fiber glass gasket material, ready to
re-install. See your Blaze King dealer.
2. Be sure the fi re is out and the stove has cooled down. Th e door does not have to be removed from the stove.
3. With a pair of pliers, pull the old door gasket out of the channel and dispose of it.
4. Thoroughly clean out the channel so the new silicone adhesive will adhere and the gasket will fit moothly
5. Run a small bead of a high temperature silicone adhesive (such as G.E. Silicone Sealer, or the equivalent)
along the center of the channel. DO NOT USE HOUSEHOLD SILICONE CAULKING. High
temperature silicone may be obtained from most auto parts stores.
6. Start the new gasket in the lower right corner. Do not stretch or cut the gasket. Distribute the gasket evenly around the frame.
7. Allow the adhesive to dry before closing the loading door.
8. Check the fi t of the door gasket. Insert a narrow strip of paper into the door opening and close and latch
the door. Obvious resistance should be felt when pulling the paper out. Repeat this check several times
around the perimeter of the door. If no resistance is felt, adjust door latch catch (see “LOADING DOOR
So I received the Rutland Grapho-Glas, as well as the material from Hechler's. Hechler's is lsited as an official BK dealer, so even though they didn't drop-ship it from the mothership, it seems to b e the right stuff - significantly denser than the two products listed in post #1. Interestingly, the Rutland Grapho-Glas is actually denser than the BK stuff.
I also got this stuff for the window:
... I used it before and I like it better than the other stuff. It is thinner in the middle 1/3, which makes it much easier to get it centered in the edge of the glass, and also makes it easier to get the metal pieces to fit.
By the way, I think Hechler's is the answer to the question of who is an official BK dealer who has a robust online presence (complete listing of products) and is willing to ship anywhere.
Belay that. It's too thin. Doesn't hold the glass tight.
So I've finished this task, using @Highbeam 's instructions: https://www.hearth.com/talk/threads/blaze-king-door-gasket-replacement.152827/
For the record, here's the materials I used:
... unlike the other merchants I mentioned in post #1, who represented themselves as selling BK parts, Hechler's is actually a dealer, and material was considerably denser, so apparently the real deal.
... and yes, it requires more than one tube if you go for a 3/8" bead.
... not official BK, obviously, but worked perfectly. Quite thin in the middle (if you use one with uniform thickness, it either won't hold the glass tight or it'll make it very difficult to get the metal retainers re-installed). Couple caveats: it's just barely long enough (for Princess, likely too short for King), so be careful with it, and it's very difficult to get the paper backing off without pulling the adhesive layer with it.
Reactions: Burnin Since 1989
Sounds like a PITA to me
Well, it's gotta be done. Sourcing the correct material was a PITA though. Would've been easier if I'd better heeded BKVP's advice to go through a dealer, and if I'd realized there was a dealer (Hechler's) with online presence and shipping.
