- Jan 25, 2013
- 96
i want to attempt to tackle the original post, "speeding up seasoning". i am not an expert in wood burning, in fact this is my first season heating primarily with wood. but i have a decent understanding of chemistry and physics.
there appears to be some confusion on humidity vs. moisture content. humidity is basically the amount of water vapor in air, there are many variables such as temperature, pressure etc. moisture content on the other hand, is amount of water in a material by weight.
now with that said, the reason wood "dries" in the first place is that there is a differential between the air and the wood, and the water will always move from greater concentration to a lower, i think its called osmosis when its a between solids/liquids and evaporation when its into a gas.. but its been awhile since i hit the books. so even at extremely high humidity there is still less water molecules in the air then there is in the wood because the wood (being a complex solid) has the ability to hold more water then air ever could (and when it was alive it was pulling it from the ground). thus an exchange occurs, water molecules leave the wood and go into the air. i'm not sure what the lowest possible moisture content would be once equilibrium has been reached, but i would guess its in the mid to high teens. obviously your climate will have a small effect on that number.
soooo....
the only time wood will be absorbing water after the tree has been cut is if it is in direct contact with liquid water or in direct contact with a solid that has a higher moisture content then the wood does. (like wrapping it in a wet towel and putting it in a plastic bag to slow evaporation). with this said, there is no way that mixing unseasoned wood with dry wood could cause the dry wood to absorb moisture, evaporation would be occurring much faster then osmosis. basically the water would go into the air before going into the adjacent wood(and whatever did in the small areas of contact would be more then negated by whats leaving the wood), this would indeed slightly increase the humidity of the surrounding air, but like i said before... the wood would still have more water then the air.
so to "speed" up the process do anything that would naturally speed up evaporation... air movement, heat,exposing to air with a lower moisture content, increase surface area (smaller splits).
as for doors and floors absorbing water... it happens, but these are pieces of wood that have been dried unnaturally to a point beyond normal equilibrium, so during extending periods of high humidity osmosis will actually put water into the wood.
hope this helps.
soooo....
hope this helps.
