ok i'm looking for a splitter and my first thought was gas.
i did a search and reading through this board i see alot of guys are going electric...
is the electric a good alternative? or am i better off with gas?
just measured the oak i have that needs to be cut and split and it looks like the biggest diameter i have is 14 to 15" some smaller stuff but most of it is 14 to 15 " in diameter.
i've read that the DR electric seems to work well but some say it is over priced then otheres say its built better then other electrics.
so what about the gas ones? don't think i need 20 tons but i really don't know.....
basically i'm lost here. there is way to many choices and too many opinions to just pick one and go with it.
intended use: well i have about 5+ truck loads of about 14" diameter logs at this time that needs to be split.. and in the spring i will most likely have a tree guy that i know dropping off logs all year they will need cutting and splitting. so it will get used but sure not as a commercial piece.
can anyone shed some light on what direction to go?
space really isn't an issue. yes the electric is smaller and easier to store but i do have room for a larger gas powered one also....
thanks in advance.
joe
thanks in advance.
joe
Alot of guys here like the Ryobi electric from Home Depot.
