Can someone tell me witch part of the burn produces creosote the first 15 minutes or during the middle?
Accumulation comes the most from start up where the pipe is cold/cool. After the pipe is hot if you make creosote it ends up on your neighbor's car.
Not if you don't smolder it. I go curious one day and took the IR thermo with me when I went up to check the liner. The stove was at 400 coming down. The inside top of the 21' liner was 240 degrees. A few degree hotter than the boiling point of water and condensation is what lets the stuff stick to the flue pipe wall.
Burn'er hot and and don't turn it down too soon it won't be a problem. And I don't care how dry your wood is, burn it too cool and you make creosote. There is moisture in any fresh load of wood not to mention the humidity in the room air entering the stove and heading up the pipe.
One of the problems I have with pipe thermometers. 18" above the flue collar doesn't tell ya squat about what is happening up top. The pipe is cooler every foot you move up it all the way to the sky.
I know. 450 on the side of a non-cat, if that thermo isn't behind the firebricks, tells you that the firebox isn't hot enough to support secondary combustion. Not a problem if you have sufficient fire going on in that firebox but a big problem if you have it shut down to a slow burn. If you monitor temps on the side of the firebox find a spot where there aren't bricks or the secondary air manifold on the other side inside the firebox. On most steel stoves that is above the firebricks and below the manifold. That spot you found before that was so hot.
You can see where it starts. The flames will be licking at the baffle and the excess gases burning up at the tubes. All of mine start it around 500 degrees. Which would be about right since it occurs around 1100 degrees inside the firebox.
Don't know why you would want to but I am wondering.
The baffle in the mag is welded in witch makes things tough when time to clean the pipes.
It don't have a dog house air witch i think it could use one.
The emissions on the 30 are much lower witch i think would give me more heat less creosote.
No doghouse?? My Uncles US 2000 has a spot in the front where air comes in? There isnt any place in the bottom front for air?
Although the 2000 has a baffle board like the 30, I dont think that the emissions will reduce overall.Sote that much.
But the 30 is one hell of a heater![]()
What's with all the "creosote" discussions on this site? I just removed a 20 year old chimney from an old inefficient insert fireplace that was NEVER cleaned in 20 years. Not once. The chimney was perfectly clean, nothing but a finger swipe coating of black soot as expected in a chimney.
I say give the creosote a rest already.
![[Hearth.com] Stages of burning wood? [Hearth.com] Stages of burning wood?](https://www.hearth.com/talk/data/attachments/85/85317-2676e7fdc85c174645ca12eef8549a34.jpg?hash=NrY_MC5N7f)
They're not all found to be quite that way.
