Start up and burn checklist
ekg0477
50
Langhorne, PA
Just coming up on one month of burning with a Jotul Insert. In the past has all been an open brick fireplace. Im looking to help my wife out with keeping the stove going all day while I'm at work.
Can anyone help me out with a check list, I kinda over whelmed her trying to explain what to do.
Thanks
on the weekend have her load it while you watch and explain the steps
Reactions: ekg0477
Assuming there are coals.
1. Open air control lever all the way.
2. Put small splits on to coals while wearing gloves.
3. Put more splits into firebox.
4. Close Door.
5. Start closing down air control in measured steps once temp reaches ____ degrees (depends on what you are measuring) as measured by ______(depends on measuring device -- in my own case I tend to go by the flue temp using a probe thermo, but with an insert I suspect you will go with the insert's temp using an IR thermometer or stove top thermo.
6. Sit back and enjoy the view and warmth.
Reactions: ekg0477
If you load it at night will you have nice orange coals left in the morning? I tried teaching my wife to shovel the ash in the morning in the front, rake coals forward, and load the wood to the top of the stove first. Then I turn the air all the way up and leave the door cracked until the new wood catches (around 15 mins) and then close the door with air on high. When it's burning well (around 20 mins) close air around half way. About 25 minutes later I turn it down almost all the way. This is with dry wood, results will vary with different wood dryness. As long as you have good burning coals in the morning it's fairly simple but my wife still didn't really want to deal with it. Maybe yours is more receptive. I try to not load too much wood late afternoon and early evening so at bedtime I have just hot coals then load it up for the night. This comes with practice and judgement with time. Good luck
Yeah I get it going most mornings from the left over coals. Today I shut the air down about half way with a fairly full load. We'll see when I get home if she decided to keep it going or not.
Firefigterjakes check list should make it pretty simple for her. I tend to overload her with info.
