Hi all,
I had a wood stove installed at the beginning of January with advice thanks to this site and it seems like our wood usage each winter will be 3-4 cords.
I would like to redo the storage area in my pole barn to take advantage of vertical space so I don’t end up taking over the entire barn. I have looked through various threads about wood sheds but I haven’t seen a storage area built inside an existing structure.
I am attaching a diagram and a couple of pictures of what I am thinking of doing. Each bay will be 8.66’ long, 8’ deep, and I am debating height.
I will be setting three posts (designated x). I am planning on a concrete base with a sonotube (the barn is in a wet area) with posts bolted to the concrete. The posts will be tied together along the top with a header and then in between the header and the ground I will be running lumber parallel to the header to support the firewood.
Questions:
1. Is it okay to tie the posts into the barn header (it is 11’ tall) or should I run a new one?
2. Should I use 4x4 or 6x6 posts, bearing in mind the posts won’t have to support any vertical loading.
3. For the lumber running below the header to hold the sides of the firewood, are furring strips good enough or do I need 2x4?
4. How high should I stack the firewood? 8’ or 10’? I don’t mind using a ladder to reach it as I bring 2 face cords at a time into my attached garage. So I won’t be constantly going up and down a ladder.
![[Hearth.com] Storage inside pole barn [Hearth.com] Storage inside pole barn](https://www.hearth.com/talk/data/attachments/275/275344-e120c72a72f64a05b4f2909b80da6744.jpg?hash=2_FuiT1PdQ)
Questions:
![[Hearth.com] Storage inside pole barn [Hearth.com] Storage inside pole barn](https://www.hearth.com/talk/data/attachments/275/275430-9684f1e77a1c2715052f085936836502.jpg?hash=Ru9W-am2pA)
![[Hearth.com] Storage inside pole barn [Hearth.com] Storage inside pole barn](https://www.hearth.com/talk/data/attachments/275/275431-a32fe61c8a23a55b22c0672d3f541a30.jpg?hash=EHtVgIByBb)
![[Hearth.com] Storage inside pole barn [Hearth.com] Storage inside pole barn](https://www.hearth.com/talk/data/attachments/275/275432-0f4201d178320bb71f876fd330fb0095.jpg?hash=piwJqvTZxz)
![[Hearth.com] Storage inside pole barn [Hearth.com] Storage inside pole barn](https://www.hearth.com/talk/data/attachments/275/275433-191a7497251a71ada2c215dd6765d1ec.jpg?hash=qqJJyim033)
