The wood burner pictured is in my basement. I can get a fire going but once I shut the door even with the air controls open the fire dies rapidly. If I crack the ash draw at the bottom open a 1/4 inch is fires right back up so I"m thinking it's draft due to the restriction in the current pipe set up. As pictured, has 3 90 degree turns. 2 are visible the 3rd turn is in the wall and then it goes straigt up the the roof (45 feet or so). I was thinking of getting a piece of stainless flexible pipe and run strait from the top of the stove to the wall. This would eliminate 2 90 degree turns. Also is it safe to paint that with hi-temp grill spray?
