I've been looking at the Osburn Inspire 2000 manufacturer's specs from their brochures and downloads. I see the brochure spec quoted as "Maximum Output" = 75,000 BTUs/hour, and the download spec "Overall Heat Output Rate (min. to max.)" = 14,800 BTU/h to 28,600 BTU/h. There is a very large difference between 75,000 and 28,600. What is the real world difference between the two published values? Is the 75,000 value of the brochure simply bogus? Overall, I'm not seeing a strong correlation between different manufacturers' claimed BTU outputs and their firebox cubic inch values. Should I just ignore the published BTU specs and buy a stove using the firebox cubic inch values instead?
