Stove or Boiler...?
jorswift
124
Indiana
I am having mixed thoughts right now. I am wanting to supplement my heating bill with wood. I live in a 10 acre wood patch with a ton of dead ash. Plus can almost get wood anywhere for nothing. I currently have a POS Majestic ZC fireplace and want to replace it with something efficient. So my thoughts, I have a 1800 sqft ranch with 400sqft bonus room about garage. I am ALL electric with heat pump. I heat my garage with small electric heater too.
1. I can get a used outside wood boiler for around $1000-2500. Install water lines, exchanger, etc and heat whole house. Use lots of wood and have to be outside to feed it.
2. finally got my wife to like and agree on something such as https://www.hearth.com/talk/threads...-clearance-to-freestanding-wood-stove.155497/ . My ZC is in the corner so this is doable. I like the look and will supplement the heating. My house is not a very "open" concept so some rooms may be cooler than others. But planning on moving t-stat to another room.
What would you do? Again, looking to supplement, not replace heating. I want to get away from the ZC hazard and have something warm and safe. Thoughts, ideas, suggestions? Thanks.
Does the house have electric baseboard heaters?
I would go with the wood stove. Cheap outdoor boilers are dirty and can eat wood like candy. With the indoor stove you will gain nice radiant heat to warm your buns on cold winter days and a beautiful fire view that's better than television. In addition to these benefits and much cleaner burning plus much less wood consumption, the indoor stove will provide heat during power outages.
Take a walk and plan where the trench for the boiler would run, from the boiler site to the wall penetration into the house. Any driveways/sidewalks/patios in the way? That could be a factor.
I'd personally be against the boiler if I didn't already have hydronic baseboards installed. You're talking about running pipe to every room in the house.... ugh.
There is also the option of a wood furnace if you already have HVAC ducts in the house- downside there is that you most likely need a new flue from the boiler room up through the roof.
The wood stove requires the least house surgery either way.
I think he is talking about putting a water to air heat exchanger in the hvac system, but that doesn't change the problems of the boiler proposal.
Boilers and furnaces are where we are forced to go, when trying to heat a space larger than one can reasonably heat with wood stove(s). You give up everything good about a stove, namely the look, the feel, the ambience, for the sake of distribution. But with a house your size, I see no reason to even consider a boiler or a furnace.
Put otherwise, if I’m doing all that work to fell, haul, process, split, stack, move, and load firewood... I want to look at a fire in my stove, damnit!
You never hear stories of the family gathered around the boiler, on a snow day in January, they lack ambience.
Reactions: PA Fire Bug
I went from an OWB to a free standing stove, 4 seasons ago, wish ida done it sooner...
Burning 1/5th of the wood heating the same space..
Both have their pluses and minuses though..
showrguy, would you have considered the boiler system heating a space that is 2/3ds smaller?
HAHAHA, right!? Cutting wood is my exercise for the winter. Right now, its fun. Who knows for how long?!?! My wife and kids love the fire inside currently. So it was be a bummer not to have it.
Yes, totally agree. I see pros and cons with both systems.
Yes, and OWB water to air heat exchanger. The boiler would be on the east side of house, since wood shed is there and prevailing winds. I have no door, access to that side of house. So would have to walk all the way around in the "dark" in the "snow" to load! It is over 100' from where I would put it to my furnace, so insulated pex be pretty pricy! Who would load it when im on vacation? I don't really want to put glycol in it....
If you leave the circulating pump and heat exchanger running, the water will continue to be heated by traveling thru the heat exchanger in your house, and it’s unlikely it would freeze. Not ideal, since now you’re using your electric heat to warm your lines, but it does work. I’ve done this on industrial electronics cooling systems, during the installation phase, on cold nights prior to finalizing and adding glycol.
There are pros and cons to both an OWB and a modern woodstove . . .
We could debate efficiency, safety, costs, wood use, temperature control, etc. but what I want to focus on is you mentioned not once, but twice, that this would be for supplemental use in a moderately sized home.
Since it sounds like you are not hoping to heat 100% or perhaps even 50 or 75% of the time with wood heat and only hope to burn wood as a supplemental heater -- perhaps just on weekends and evenings as some folks do here . . . and since you are not looking to heat a very large home . . . I would respectfully suggest a modern woodstove vs. OWB, recognizing that while you gain the picturesque view of the fire, reduced wood consumption, etc. you will lose out on a more even temp throughout the entire home with an OWB.
Reactions: Marshy
And super expensive compared to a stove.
Yes indeed. As most full meal deals are. :)
(OP also kind of glossed over the costs of all the other stuff that would be involved aside from just the boiler...)
Reactions: Highbeam
A lot of things can go wrong with a boiler. Stoves are much more simple and reliable. The more complex a system is, the more likely you will have problems with it.
Reactions: Ashful
I have a buddy with the old style outdoor Central Boiler. One thing that's nice is you load it up, shut the boiler door and walk away. Wood stove inside takes just a little more attention to get the fire settled in. If you want to heat your garage too the boiler would make sense. If not indoor wood stove all the way.
Sent from my SM-G950U using Tapatalk
Sorry BG, just saw this now..
I'm not sure I understand your question, but when I built this place in 2001/02 I put over 2 mile of radiant tubing in all the froors, including basement and attached garage, installed a Mahoning multi-fuel OWB, chose that because they have a seperate combustion chamber that you can use an oil or propane burner, I had propane for 'just in case'..
That thing paid for itself after the 2nd heating season, radiant heat is awesome btw..
Back then a tri-axle load of logs was about $450.00 and easy to get, now that same load is $700.00 -- $800.00 and can be hard to find..
The OWB was great in alot of ways, but the biggest draw back was it ate alot of wood, I did'nt care so much when I was in my 30's and 40,s, but now I'm in my early 50's, and handling sometimes 20 cord of wood over a long, cold drawn out winter got to be like a full time job..
I installed the BK King almost 4 years ago, knowing that there's no way a single woodstove was gonna heat my whole house !!
I was wrong..
It's much easier to mess with 3-4 cord with the King, the only drawback is you must have dry wood, little more mess inside, no warm floors, but I can deal with all of that !!
What I like about boilers (any hydronic boiler,not just wood) is that they are so versatile. Radiant floor heat, water heating, snow melting... you can even heat your swimming pool/hot tub. Radiant floor heat in a large barn/shop concrete floor just can't be beat when you have to lay down and crawl under some piece of equipment. While not nearly as efficient, affordable simply reliable or arguably practical, they are great for a lot of things a stove just can not do.
All that said, you'll pry my plane jane wood stove from my cold dead hands..LOL..
