Stove Purchase
HighHeat22
172
southern michigan
I have been looking to buy a new stove and have settled on the pleasant hearth 1800 sq ft model. It was between this or the nc30. If you look at their firebox dimensions the pleasant hearth seems to have a bigger fire box at least in height which says 19 inches compared to the nc30 which says 13.75 even the width shows bigger at 25.5 inches compared to 20 inches. Does the pleasant hearth have a bigger fire box than the nc30. I know everyone raves about the nc30 but I like the pleasant hearth better and I am limited in depth space and the pleasant hearth is much lighter. I have a 1800 sq ft ranch to heat.
Also, I have been looking at the Home Depot site and if I change store locations I am getting different prices for the nc30 but not the pleasant hearth the lowest I find is 749.00. Does anyone show a lower price in there area. The Lowe's site was much higher for this stove at 1050.00. I know they will price match but I really dislike Lowe's. I figured these prices should be dropping with spring right around the corner so I have time.
I think in the end it depends on your preferences and what will work for your install. I have heard plenty of good things about pleasant hearth stoves. But I also used to own a nc30 and it was awesome. It put out a ton of heat. In general lighter doesn't mean better. In the stove world weight of a stove is generally looked at as a good thing.
If you could elaborate on your setup we might be able to give you more pointed advice, example chimney length and setup, stove location, size of house wanted to be heated, insulation quality?
Be careful about reading specs. Sometimes they are not what they seem on the surface. For example some stove mfg. report the the full firebox dimensions including above the baffle when reporting firebox height and firebox capacity. FWIW, Englander stoves have a strong track record. Durability and service are also important factors that don't show up in specs. Drolet is another brand to look at in this price range.
And even when acting in good faith (not always to be assumed), different companies have different protocols. I have a Jotul F500 Oslo, rated at 70,000 btu output. I also have an Englander 30 NC, rated at "75,000 + btu". I burn both from the same woodpiles, and the difference in heat output is far, far more significant than those ratings suggest. And why shouldn't they be? The Englander has almost 50% more capacity and far more surface area to radiate heat.
I understand what is meant about the weight of the stove the heavier material is better. But, I still have to get this stove in the house and even thou I will be building a new hearth 500 versus 300 lbs weight on the floor is a big difference. I have looked at the Drolet and I think I am sold on the Pleasant Hearth. Stove is going in a corner with a 44 inch depth and a hallway starts so I have to be careful with my stove depth.
I would like to know if this stove goes on sale anywhere in country on the Home Depot site. The NC30 and NC13 are both on sale right now but not the Pleasant Hearth model. I would imagine it will not be long coming into spring. You can buy from any location and ship to home.
I have a very easy setup in our new 1800 sq ft ranch home. Its a straight shot up with an 8 ft ceiling in the living room. About a 17ft chimney length. Very much different than what we have now a 28ft chimney length with an open second floor 17ft ceiling. I have about a 45 degree bend at the ceiling. This open ceiling setup has not been good at all. I am way under powered in this 3200 sq ft home with an old country stove. We are downsizing and will be moving into the new house this summer and I can not wait.
Check Ebay for those stoves. There are a Few deals with shipping. I found my last one on there and paid $700.00 for 2 of them. I had to pick them up about 2 hours away.
You might consider the fact that the NC30 is made in the USA with highly reputable customer service and a much longer track record for being rock solid. Not that the pleasant hearth isn't a good heater, but it's a Chinese made stove with little or no dealer support from what I understand...
Reactions: brenndatomu
I have not used either stove, but I can impart one little bit of experience, I would lean toward a shorter/wide firebox over a taller one. The shorter box will produce those awesome clean burning and heat producing secondary flames easier and for longer than a taller box. If you want a small fire in the taller boxes, it seems you have to get creative in stacking the wood in there in a log cabin or teepee style to get the secondary burn to work well...gotta get that fire up close to the baffle...at least at first. 3 splits in a tall box may burn...but not real well in my experience.
And the difference in weight says a lot to me...I'd go for the 500# made-in-the-USA stove over a 300# china stove everytime...the little extra hassle of dealing with that extra weight during install is a small price to pay for years of heat from a really smooth running stove like the 30.
And don't forget customer service, does Pleasant Hearth have a rep on Hearth.com like Englander does? I've seen him go above and beyond more than once...priceless
Oh, and the 30 is on sale for $519 from the Durango Colorado stove...another $99 delivered to your door...and I hear that often times a couple extra greenbacks to the delivery guy will get it inside your door. Once inside it should be very easy to get it to its permanent home via a 2 wheel dolly. $618 total delivered price for a stove like the 30...no brainer decision to me
Englander would be my choice. Both will work but the Englander stoves do have a reputation for heating and service. In the end, you can't throw $300 at the Pleasant Hearth and make it an Englander after the fact. You really do get what you pay for.
"Rated up to 1800 sq.ft." is if you live it a tight house in Georgia. Go bigger.
OK, I have been swayed to buy the nc30. Good point by all.
Congratulations. I think you'll be happy with your purchase. Read up on the hearth requirements. This stove needs good insulation in the hearth.
Sq. ft. mean nothing. It assumes a "standard" ceiling, which may not be correct.
All that matters is the volume to be heated and that is independent of sq. ft. (all the difference in the world if you have cathedral ceilings versus "standard" ceilings for the same sq. ft. floor space).
Think instead of cubic feet or cubic meters. In other words, one needs to think of volume, not area. There are many web sites that give the needed BTU or KW needed to heat a specific volume. Look them up before purchase of any stove.
Also important is the heat loss of the home. That varies a lot. Room volume, insulation, glass area, sealing, climate zone, fuel species, and operator are all variables that affect the area heated.
Reactions: St. Coemgen
