So the manual for our unit says to have a 500 degree temp to switch to catalytic operation. We have been using stovetop thermometer to determine temperature. We have 2014 VC Defiant. Since stovetop temperature is probably different than temperature at the catalytic element is this the correct way to know when to close damper and run catalytic? Thanks in advance for your wisdom. Appreciate you guys.
I close the damper to run the cat when my stovetop thermometer says 400 degrees. One way to see if the cat is working is to look outside at the chimney when the damper is open and then look out when you've changed to the cat. The particles should be much less with the cat. It's my understanding that the cat will not be harmed by switching at a lower temp, it just won't activate and the fire may die back without the draw from the open damper. I don't worry about opening the damper when the stove is dying down for the night.
