Hi there..
As I'm usually hesitant on making new threads to ask questions and do try to look for possible posted answers to my questions (which are usually have been answered already) before making a new one. But on this issue I really can't find the answer.
As for background, here's my intro post:
Sakuji's Planned Install
- BK Princess Insert: already paid/waiting for delivery.
- Duraliner Combo: after considering all factors we concluded (hopefully correct) that this is the appropriate liner system to use on our set-up.
As I'm in the process of making a list and about to order the needed stuff for the Duraliner, I got stumped by this simple issue: Top Plate.
My chimney top is similar to this![[Hearth.com] Terra Cotta Top Plate in-place of Extend-a-Cap for a Duraliner Install: feasible? [Hearth.com] Terra Cotta Top Plate in-place of Extend-a-Cap for a Duraliner Install: feasible?](https://www.hearth.com/talk/data/attachments/165/165999-1ec9f2f36d58301d2ebdddcf988b0406.jpg?hash=AFrUg7lhdz)
But without the furnace vent. The top 13 x 13 clay flue extends vertically 8" (yes 8") inches above the crown and based on these discussions: 1 and 2 (plus a couple more), just silicone sealant and perhaps 90' folding of the lips has been done and found adequate for the Extend-a-Cap kit. Fact is that is the manufacturer's recommendation and also said that if feasible anchor bolting of the plate down to the crown which in my case is not.
However, just for the sake of discussion, is it feasible for me to use a Terra Cotta top plate instead and a cap like this in place of the Extend-a-Cap? Both of those can come at various diameters that may fit the top portion of the (broken link removed to http://www.northlineexpress.com/media/gentosonic/ewminify/media/inline/22/5/6-x-48-duraliner-round-rigid-chimney-relining-pipe-6dlr-48-596.jpg). The reason I'm asking this is because I think that the Terra Cotta Top Plate is the right design call when terminating on a vertically extended clay. As far as I can recall Duravent have not mentioned the removal or cut-flushing of an extended clay flue. It just mentioned the bolting of the plate + silicone. However, certain manufacturers also gives us the specific option of a Terra Cotta top plate which has those side facing pressure bolts to hold unto the flue which is I think is the better design call for these set-ups.
So far the only mods that I see from the standard Extend-a-Cap is that instead of a three point screw to hold the cap it will be a clamp instead. The storm collar and the rest of the plate will be replaced by the integrated terra cotta plate. What you think, guys?
Of course these are just the musings of a totally green horn with zero liner install experience. Or somebody did this already (which is more likely). Any feedback is appreciated.
Thanks.
Thanks.
![[Hearth.com] Terra Cotta Top Plate in-place of Extend-a-Cap for a Duraliner Install: feasible? [Hearth.com] Terra Cotta Top Plate in-place of Extend-a-Cap for a Duraliner Install: feasible?](https://www.hearth.com/talk/data/attachments/166/166109-6e2f8ab881568d4769dffce454070f10.jpg?hash=_--3_rqYw-)
