Hello,
New poster here, been in the shadows reading and reading, searching and reading more, gathering all sorts of useful information that has made my transition from the oil company to wood a smooth one. The quality and depth of the posts on all subjects from types of wood, chimney and stove info, drafting, safety, installations, etc, is above and beyond what I expected to find. Thank you to all that contribute here, either with just one post or dozens of them, they all pitched in to fill the voids that were left after reading manuals, web pages and listening to salesmen.
Put in a new Hearthstone Shelburn, full install, from the hearth, to the double wall up to the through the wall kit to the Selkirk stainless running 16' from there up the outside of the house. Everything went together as it should, it's been up and running for over a month now and what started as a "comfort" back-up heat source has since turned to 4 cords of wood stacked up, heaters turned down as far as they go, and a house sitting comfortably in the 70's (first time since I've owned it) aside from the -8 temps we woke up to today.
Thanks again to everyone, you've all been a great help, keep the info comming!
John.
![[Hearth.com] Thanks to all that post here... [Hearth.com] Thanks to all that post here...](https://www.hearth.com/talk/data/attachments/120/120911-9cde5a24b934a316b7e02da98d561669.jpg?hash=vmo8CnoecH)
Had I truly known how heavy 400 pounds of dead weight was I would've never picked the stove up in my truck or unloaded it by myself. Why those 2 by 6's didn't snap is beyond me!
![[Hearth.com] Thanks to all that post here... [Hearth.com] Thanks to all that post here...](https://www.hearth.com/talk/data/attachments/120/120912-6672faa191f177cf878890b10738fca2.jpg?hash=AcDGUJF3_s)
Not wanting to use a "telescoping" section of pipe, and needing the double wall for clearance reasons, it was key to dry fit everything inside to determine the exact height of the hole location, as well as best estimating the length of the through the wall pipe (went with a 2' section of metalbest) being off just an inch or two would've resulted in either a telescoping pipe or a couple of 30 degree angles needed.
![[Hearth.com] Thanks to all that post here... [Hearth.com] Thanks to all that post here...](https://www.hearth.com/talk/data/attachments/120/120913-5865ffea5b387e3e2c988e22db7902ce.jpg?hash=HHTTWz9nXa)
Despite exceeding the minimal distances required the wall was getting too warm for me to sleep easy as night so we ended up making a couple of panels from cement board and tile. Pre-installed 2" angle brackets on the back to line up with the wall studs, then tiled over the heads of the carriage bolts holding them in place. Put 2" brackets on the wall that mated up to them and presto, heat shield with 2" stand off and no direct heat transfer points. Not that this is key, because I'm still exceeding minimal clearances, but it's good practice.
John.
