I know you guys love your Oslos’s but I’ve got a story to tell! Scared the crap it fo me! I loaded my stove before bed two half burned white oak logs close to charcoal state but still holding together. Loaded an additional 3 big splits of oak. Primary was 1/2 open and left it that way for 5 minutes. Closed the primary completely an watched the fire grow normally about 20 minutes late I had great secondaries and some yellow flame on the logs but not much at all. So far so good. Everything normal. I fell asleep in my chair and woke up about 1/2 hr later to blistering heat and what looked liked a nuclear reactor in meltdown. Remember primary was closed. Everything in the firebox was burning at once. The flames filled the entire firebox and looked like plasma more than flames. Secondaries were turbulent, blue and blowing HARD against the front glass. All the wood was being consumed at once in a conflagration. A fire that should have lasted 6-8 hrs was down to coals in 30 minutes. Never saw this before. Not with this F500 or my previous F600.
I have a 30’ straight run of double wall up through my roof of the great room. Temps are hovering around zero F outside. Like I said primary was closed. This was all secondary air. I don’t think Jotul had this situation in mind when they designed the stove. Gaskets are all good. The stove was well behaved this afternoon when temps were about 25F. I did nothing unusual. This has to be an overdraft! Never seen one before but I can’t imagine it can get much worse. No signs of any parts of the stove glowing. Certainly scared the sh*t outa me. Should I install a key damper to control the draft?
