Do you have the cat temperature probe installed?
No it didn't come with probe? Should it have?
The cat should glow orange View attachment 223634in the beginning when active.
Thanks. Finally got it going correctly...now what's a good cleaner yo use for the glass haha
Thanks!I actually use goo gone oven cleaner. It was recommended by someone else here and it does pretty good. Found it at Walmart.
When you test your wood you need to split the piece of wood and test the wood on the fresh cut. I suspect the wood still has a high moisture content.Just had the Ci2600 installed. This is my first stove and i have no prior experience with any wood burning stoves. Having a really difficult time getting it going. Glass is already black. Have my own cut and spit wood. Bought a moisture meter and its showing areoun 17% . My biggest question is if I activate the CAT to early is that a big problem? Im having trouble trying to figure out when to activate it. Also If i close the damper even just a little bit the fire burns out and fills with smoke
I did not see that you got it going correctly so I guess your moisture is good.Thanks. Finally got it going correctly...now what's a good cleaner yo use for the glass haha
I am having an HI400 installed in about 4 weeks, my dealer confirmed specifically that the cat probe is included. If you look at the regency website, it clearly states that it's included. Others here confirm that new stoves come with the probe. One dealer added a $191 line item on the proposal for the cat probe, which is absurd since it's included. They obviously did not get the sale! I would make a stink with your dealer. If your stove is old stock, it possibly also won't have the restrictor plate. Others in this thread have mentioned they suspect regency changed a few other things for newly made stoves besides just the restrictor plate.Mine came with the probe. Maybe they are selling them separately now.
What stage of the burn are you at?Just curious if this is what I should see coming from my chimney when fully closed down.
https://drive.google.com/open?id=1FAKjndZaFZIut9cXOZVB9HdSHXqjTyq5
https://drive.google.com/open?id=1dPY0LvoriZ57p_QWJfBSA3j4C5zGeT5-
It’s seams ok. How long do you see smoke?
Check to see if your cat is crumbling.
The name of the company is firecat if it’s under 3 years they cover 100% over they cover a lowering percent every year that passes. Send them the crumbled cat with copy of receipt for the stove.Thanks Wolves1. We are almost out of wood. So wanting to get the last few days of good heat and then when all cooled down I will check it. If it does need replaced, any good places online I can buy one or do I have to go through a dealer?
Mine is definitely crumbling after 2 seasons... could have been earlier but I didn't notice this until well into our current season. I have attached a pic. I have a couple of questions
1) Should this be happening at all or is this normal wear and tear (See picture).
2) I have not been able to get a fire over 1300 degrees this year and rarely got one over 1200. Last year I could easily get to 1300 degrees. Could this be the culprit?
Thanks in advance!
