I have a an Englander 25-pdvc/55-shp10 stove. The bottom auger seized up and the top auger jammed up as a result so I replaced both motors. I also noticed that the vacuum hose was cracked so I replaced that too.
The bottom auger runs fine but the top auger does not run. I verified that both motors work, by powering the top motor using the bottom motor wires, the top motor turns and runs constantly.
I bypassed the vacuum switch by jumpering the contacts together with a paper clip. The top motor is wired in but not connected to the auger so there is no load. It does not run. I also do not see line voltage at either of the vacuum switch wiring leads, or at the vacuum switch contacts on the control board.
I rebooted the control board and there is no change. It seems that the control board is bad. However if I disconnect the vacuum switch leads and leave them open, the unit goes into E-1 error mode after just a few seconds of operation, which leads me to believe that the control board is actually working.
Any thoughts on this?
![[Hearth.com] Top Auger problem or control board? [Hearth.com] Top Auger problem or control board?](https://www.hearth.com/talk/data/attachments/219/219931-7cbf68f4ca952c4cc6e751d02448b69f.jpg?hash=chQ8XGz3GR)
