Im working on trading my heritage for a mansfield,other heritage owners who have moved up to the mansfield ,have you noticed enuff of a differance to justify the expense....Im dealing with -20 temps and -50's wind chill and its been steady for weeks and more of the same forcasted...im thinking the extra 20-25 k btu output should let me sleep all night with out a reload going to bed at 9:00 pm up at 5:00 am heating a 1500 sq ft ranch top floor only..any thoughts???ZZZim
There is a HUGE difference between the two stoves. I used to have to reload my stove every 4 hours when it was 10 or so (even a little warmer). Now, I can go easy 7-10 hours. What you will find is that the Mansfield works in much the same way as the heritage as far as cycles. I had to keep the heritage at 400+, which meant reloading often. Now, the Mansfield will give me the same results at 275-300. The "bigger rock" at a lower temp did the same job. I also have noticed that to bring the house up from 60 to 70 when temps are in the teens is doable in a matter of a few hours when starting with a relatively cool (or cold) stove. The heritage could never really achieve that, it would bring it up a few degrees and then take forever to get the temp back up to 70 in the house.
