This is a friends tractor it run sweet for 20 mins then the only way it will run is with the choke on?
You can try this first, but it's most likely the jets in the carb are plugged up and you'll have to remove the jets and clean them out. Usually the result of letting old gas sit in carb too long, which is common in seasonal use engines, but maybe just from debris like rust.The carb need cleaning (probably). Get to the front of the carburetor, disconnect hoses, screws etc...and spray carb cleaning stuff in all the openings. I think I did this without removing the carb once. Do it a couple of times. Also add some seafoam to the gas tank and let it sit over night after running it. Could have something in the fuel line. Blow that back to the tank.
If you want more serious help from a very experienced crowd go to weekendfreedommachines website
forgot, you can download the service manual here: (right click and save as)
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2379.pdf[/quote]
I think your dead on with the head gasket
you might fid something like this
(broken image removed)
it would still start!
Oh he is...lol I will let you know but he wants to replace either way..... i dont have a link to the la135 manual, hell they want like $80 for itEvery thing thats been mention is already new or on its way. This is one really good example of a 212. New gas cap came in yesterday. It no longer showed how much gas was in it so thats was the reason it got replaced(But not the issue). Head gasket, points are on the way. Coil check by dealer but a new one is still on the way. This is more of a rehurb so if you can think of anything else feel free! Even the knobs and gauges are new. Makes me want one!
I didn't see it in the list. You gonna do a carb rebuild on that? The kits are pretty cheap.
It may be true, but I would still pull the carb down. I think that is your running issue.
See what happens with the other parts first. If that dont handle it that will be next.
Well, from your first description...After 20 minutes you have to pull out the choke and then it runs relatively normal... that ain't spark...thats fuel. But it sounds like the dude is doing a full resto - so it probably ain't a big deal. He will get to it eventually.
Well, could be spark then.
Makes me want one!
Got a feeling it will look something like post 7.
