You boys need to read...closely. Very closely, especially the B². BTUs are what you get as heat, such as : warmth, ( fill in synonym here____ ). ( Kindly Google "BTU" )
Now to the reading: any wood device that burns with an adjustable, primary air that can be shut near down will keep good hardwood glowing ( that's coals ) for a long, long time.
Now dear readers and you two doubties, those glowing red coals may not produce those wondrous BTUs ( see "heat" ), but it is a "fire" according to those above doubties.
Question for the BK (and B² ) lovers: How much heat ( BTUs
) does that BK produce after the "30 hour burn time" with the one and only load ? Got heat ?
Now dear readers, BTUs are real measurements of produced heat. If a loner off in the ether believes that "btus per load" is only for sizing, there is a lovely bridge for sale in Brooklyn. Or, "I will love you in the morning dear. "
Or, "the check is in the mail." Or.....
So back to Earth boys: have either of you actually used the VC Encore ? Really really seen one in use and received those BTUs ? Curious minds want to know.
Me too....huh.
Update for the High and B²: the flue needed its annual brushing today. Since it was chilly ( 37
) YESTERDAY morning @ 0530 , we loaded the Encore about 2/3 with Red/Soft Maple for a quick, warmup heating.
After the usual cat steps--ignite, let the fire roar, drop the cat bypass, let the stove get back up to temps, then drop air all the way down ( near zero air ). At 0730 this morning the stove was warm, the 3 splits were coaled red.
Opened the cat bypass and primary air to burn out the load. Climbed the roof @ 1230, after the flue and stove cooled for the flue haircut. CAN YOU BELIEVE ? Mirabile dictu.
No carbons were destroyed in this stated burn or message.
JMNSHO
