Guys,
I have a mix of seasoned hardwood(50 splits/ pieces) and semi seasoned (4 months) (150 pieces) of wood to burn this winter. As you can see, I've got very limited resources to leverage this winter. I have an EPA rated insert (Rockland) that is awesome.
Here's my strategy to heat the house - I use the seasoned wood & kindling to burn a very hot fire. Typically 2 splits - I let it cruise with 2-4 of semi seasoned wood. I do get some coals but the semi seasoned wood burns. I currently use pellets (picked up from Home depot) to stimulate the burning process and maintain heat. I put 4 small pellet packs (made with standard sized paper with 2 hands full of pellets) as steroids to make the semi seasoned splits catch fire. The pellets catch fire and burn down the semi seasoned wood. I only see steam (no smoke) from the chimney with this approach.
When cooling down the stove (I only have limited wood to strategically heat during the coldest days and the weekends), I use pellets to burn down the coals.
Q1) Is my strategy safe (for the insert)? I only use limited quantity of the pellets to stop the stove temperature from falling.
Q2) Is my strategy sound? Do you have any recommendations to improve it?
