Ive been having a problem with my USSC 6220 Pellet Furnace. For the last 6 weeks or so, every time I shut it down for cleaning, I have a hard time getting it to start up again.
The problem is that upon lighting it, it just wont feed pellets for anywhere from 30 to 45 minutes. Eventually it starts feeding and it remains working fine for a full week till I shut it down again. Then the problem repeats.
Ive tried running the test procedures and the auger runs fine during the test. But during initial startup it doesn't even try to run for as I said, 30-45 minutes. Then it works normal. Ive done factory resets and run diagnostics till I'm blue in the face.
I thought it must be the circuit board was going bad as I was having a couple other minor problems. (numbers not lighting up and exhaust fan acting strange), so I just bought and installed a factory new control panel. All the problems were fixed except the auger feed on startup problem. It remains.
The vacuum switch tests fine and the thermistors are reading temps. Not sure they are reading the correct temps or how that might affect things. I guess I could use a infrared thermometer to check the readings against the thermistors readings in the test procedure.
Anyone have any other thoughts?
![[Hearth.com] USSC 6220 delay in auger [Hearth.com] USSC 6220 delay in auger](https://www.hearth.com/talk/data/attachments/308/308394-b111f874b3a95ebb554de559cf98df25.jpg?hash=xOnY6mIuTf)
![[Hearth.com] USSC 6220 delay in auger [Hearth.com] USSC 6220 delay in auger](https://www.hearth.com/talk/data/attachments/308/308393-78118c80c43a67884ab73e3d5b7ed462.jpg?hash=Gzw4nXG4aQ)
