Vacuum attachment for vent?
jatoxico
4,369
Long Island NY
Hi fellas, I want to be able to vacuum out the heat vent of my insert. I didn't measure but it's probably 1 1/8" and no more than 1 1/4" and just about 2' deep. Ideally it would have some type of brush to loosen dirt etc.
Anyone use or run across anything that might fit the bill?
No idea what that is, but it sounds like you could stick a 1.5" wire-handle pipe brush into a 2' piece of 1" OD tubing and stick that mess onto a shopvac. :)
Maybe tie a piece of string to the brush if the handle is shorter than 2'.
Thanks I like the bottle brush idea to loosen the dust. My vac attachment will only get about 1/2 way in but I guess I could crank the fans and blow everything thing out then deal with it after that. Probably get a face full but in the scheme of things its a pretty small problem.
I think you have same insert as me (hampton hi300) i duct taped a 2' long ½" or ¾ piece of pex to a shopvac crevice tool and vac away! Swiffer dusters work well too.
Reactions: jatoxico
