Still can't figure out why my portrait photos post sideways sometimes... sorry all!
Posting from iPhone?
The phone was meant to take pics sideways? Put the button to the right and take a sideways pic? The phone will post straight.
Did you try turning it up? THey do have temp adjustments on them. I run my 30 gal about half way up(5 of us) ,but bump it up higher if we have company (7 or more).Been here 25 years and went through about 3 HW heaters but never had a need to go bigger.Same here.. Washer, Dishwasher, wife with hair to her @!$, 2 kids and myself. My 50 gal doesn't get it done. And that's with my 2 minute quick shower. Prob gonna step up to a 75-80 myself.
t
Do you run it on "heat pump" only or the mix ( not the correct name ) setting?
I'm thinking of getting one right now I could get one at Lowe's for $250 after rebates etc. Problem is I just installed a new electric hot water tank a month ago haven't even got my first bill for it. Not sure I can convince my wife to do the hot water tank exercise again to get it into the basement.
post a closeup pick of your yellow sticker please on the mararthon, my 50 gallon heater was installed 2008, came with my house when i bought it, it says something like $454 a yr energy cost, now enjoy $200 a month electric bill's
. Turns out when you need one in a rush you pay the price. I am just fortunate lowes had one in sock. Old one was a 75 gallon that had the bottom blow out of it mid-day. Set the house alarm off and I came home to the police clearing my house room by room with guns drawn.... Fun.10 gal per shower.... Thats what, 3-4 minute showers? How do you guys manage it Seasoned.....
We must take pretty long showers as we ofter run out after 2 back to back on our 40 gal indirect. Never could figure out why it cant recover fast enough heating off the 140k boiler either...
I think I could run my water continuously with my 40 gallon indirect and not run out. The boiler was 75k. What temp is your boiler running at? Do you have hard water maybe your getting really bad heat transfer.
Im not using all hot. Have the shower valve at about half/half . 10 Gal With a 1.2 Gal SH would get you about 10-15 Min. Wife showers much longer about 30 MIn so she goes through 20 Gal+.Claims she never runs out. Also I do have a tempering valve that mixes some cold so you dont get scalded. At times when we have more people in the house i simply turn up the temp further to make the water hotter. Hence the mixing valve mixes MORE cold in you actually use less hot water from the WH. Both the dishwasher and our Washing machine have their own built in WH so they always work at the correct temp. WIfe and i almost never take back to back showers at least when were not sharing a shower.10 gal per shower.... Thats what, 3-4 minute showers? How do you guys manage it Seasoned.....
Anyone in this situation will need a large WH. Only other solution would be a smaller one run at high temp with a tempering valve.. We go in succession 1-2-3 in the morning, and with the boiler its not a problem. I go last... so I want to make sure if I do this, I still have a hot shower.
20 minutes is more standard for real people and if you start that clock when you first open the faucet then I believe that very few regular people take 10 gallon showers. So 20 minutes with a low flow 2gpm shower head is 40 gallons. But wait, shower water is not straight 120 degree hot water, it is mixed with cold 55 degree water to get you from 120 down to 100 degrees or so. This means that your 40 gallon tank can make way more than 40 gallons of shower water and while you are in the shower, the water heater is trying to recover.
A 50 gallon HWT is very standard for 3 bedroom homes. Anything smaller might actually hurt the home's resale value. There is no real downside to a large water heater, the element sizes are the same. You're just storing more heated water.
The upside is a smaller footprint.
Good job on the marathon, bad job on the install. I can overlook the concrete blocks but the exposed romex cable hanging there is not per code.
What can I do to make it up to code?
