Short flue, warm outside temps can combine to make for weak draft insufficient to pull enough air into the stove.
BeGreen said:Yes, so did others. But sometimes you can lead the horse to water and still...
oldspark said:Are you sure the wood is dry and I mean really dry like a popcorn fart, cause if the wood aint dry your life will suck and the wife will leave you and the kids will throw rocks at your head. :lol:
NATE379 said:Sure you can load it up and light it. That is what I do. I don't use kindeling or small wood. I fill stove, throw in a fire starter at the bottom and it's burning in a few mins.
I wouldn't do that if it's warm out thought (over 30*) I would just use a couple logs so house is not 100*
:zip: :lol: That was funny.....oldspark said:Are you sure the wood is dry and I mean really dry like a popcorn fart, cause if the wood aint dry your life will suck and the wife will leave you and the kids will throw rocks at your head. :lol:
wowser said:WOW, first off, thank you everyone. I was at my daughter's school performance so couldn't respond.
Yes, I live in Southern California, so a wood stove isn't a necessity but is nice to take the chill off the house. Right now I am just trying to learn how to use the stove and, hey, it's a new toy...
I think you've all taught me how to burn this thing right. Get her hot and a bed of coals, then load her up with lots of wood. I thought you could load it up at the start. It's going great now! Not sure I'll get 6 hour burns, but I'll keep trying. How long do you guys get flames on your stove? Since this stove is for more show than heat, it's nice to see a flame instead of some coals.
How do I use the air control? I let the stove get flaming for about 10 min and then try and throttle down in 1/4 increments. If the secondaries are going, I figure I am good. If I throttle down too much and the flame dies out, I turn it back up. I was able to throttle all the way down after I took everyone's advice. First time :>)
thechimneysweep said:I'm surprised nobody has jumped on the reported 7% - 12% moisture content in your wood. We shoot for 20% - 25% moisture content because at that point most of the free moisture (water) has evaporated away, leaving the bound moisture (wood resins) behind. When a fresh load reaches about 500 degrees, these wood resins begin to gasify, and the gases ignite, which provides the fuel for Stage 2 of your burn. This is when the secondaries light up, and provide up to 50% of the heat from that load.
If your wood is truly at 7% moisture content, much of the bound moisture has evaporated away, taking its fuel value with it. When fueled with wood that dry, your fire progresses rapidly from Stage 1 (kindling the load) to Stage 3 (charcoaling), resulting in disappointing heat output and short burn times (sound familiar?). Yours is a common complaint we hear from folks who burn mill ends, because much of the resin content has been baked out in the kiln.
The solution? To start with, do exactly what you've been doing: chop the extra-dry pieces into small splits, and use them to start your fires. But from now on, try this: once the fire is going, fuel it with larger pieces that aren't so over-seasoned.
I am saving this post (where were you on "can wood be too dry posts" :lolthechimneysweep said:I'm surprised nobody has jumped on the reported 7% - 12% moisture content in your wood. We shoot for 20% - 25% moisture content because at that point most of the free moisture (water) has evaporated away, leaving the bound moisture (wood resins) behind. When a fresh load reaches about 500 degrees, these wood resins begin to gasify, and the gases ignite, which provides the fuel for Stage 2 of your burn. This is when the secondaries light up, and provide up to 50% of the heat from that load.
and hoping others get something out of it.
! WOW! Fortunately I tested other lighter wood and it read just under 20%, so I'll hold the darker wood for next year. I'll be testing the wood I put in the stove from now on. Can take a reading from the cut end of the wood? I've been having to chainsaw off around 5-6" off the end because it won't fit in the firebox.DaFattKidd said:oldspark said:Are you sure the wood is dry and I mean really dry like a popcorn fart, cause if the wood aint dry your life will suck and the wife will leave you and the kids will throw rocks at your head. :lol:
This might be my favorite post ever! Holy crap I was cracking up when I read this.
Doing The Dixie Eyed Hustle said:DaFattKidd said:oldspark said:Are you sure the wood is dry and I mean really dry like a popcorn fart, cause if the wood aint dry your life will suck and the wife will leave you and the kids will throw rocks at your head. :lol:
Put it in your sig, D![]()
BrotherBart said:jharkin said:If it was 60F outside I'd have the windows open, not the heat on.
Not if you live in Southern California. The ridiculous assumption everybody makes here is that everybody else lives where they are with the same weather. People that deal with 90 degree summers can be freezing their ass off on a sixty degree night. All houses aren't built like they are in Alaska. Not everybody has five kids and the oven in the kitchen running four hours a day. It is different stuff for different folks.
Somebody in South Carolina trying to keep their house from being 50 degrees inside does not give one damn what ya deal with in Fairbanks when the temp may only vary ten degrees in twenty four hours. That is wood burning heaven. Try 50 at noon and 22 by morning. That is a wood burning challenge.
wowser said:okay, I'm starting to get this thing now. I got a great burn overnight thanks to your help. I fed the box nearly full at 9 pm last night and woke up to a big pile of hot coals and the stove was about 170°. Didn't take long to get it fired up again. Not sure how many hours that is though. Wondering what a "six hour burn" means? Is that 6 hours of flames, big coals, 400° stove temp, what?
Also, nobody mentioned where the intake is on my stove. The lever is at the top and there are some covered louvers next to it. I assume air goes in there but does it channel to the bottom, front? What I want to know is if the bottom air intake can get clogged.
