I believe some sort of offset will be required (mention was made of a 45 degree).
I assume the liner connection should be screwed, but I have other questions:
1. Is sealant (Rutland?) required at the connection?
2. Should insulation be stuffed between the liner and the interior of the SL300 pipe?
3. Should insulation be stuffed between in the annular opening of the two rings of SL300 (is not operating as an aircooled chimney)
