Yes 😂 not sure which one, maybe both? I bought it in log form and really couldn’t tell the difference by the bark.Do you have red or sugar maple?
Sugar is much denser and heavier than red when seasoned, very close to oak. In my experience on mature tree's, red has a finer more regular bark pattern and sugar is more irregular. Red also seasons quicker.Yes 😂 not sure which one, maybe both? I bought it in log form and really couldn’t tell the difference by the bark.
I’ve only seen Red growing around here in our sandy soil. I think closer to Lake Superior there’s Sugar. I probably have a mix, some of my splits are just as heavy as similar sized Oak.Sugar is much denser and heavier than red when seasoned, very close to oak. In my experience on mature tree's, red has a finer more regular bark pattern and sugar is more irregular. Red also seasons quicker.
I asked because right where I am there's no sugar, only red. 2 miles east of me it's almost all sugar. The DNR forester that used to live next door told me that's because of soil types. We're right by a border of a soil type change...
My insert gets little use( its on the opposite side of the house from my wood stove) so i always have ‘cold starts’ and downdrafts. I found using the heat gun or a hair dryer to heat the flue as you described gets the smoke going in the right direction. I tried just burning some paper at the top of the burn box but that didn’t always work. So the heat gun became part of the startup procedure.Alright, hanging out in the basement with the princess, (sshh don’t tell the wife) first ever light off of wood stove #2 and it went ok, the stove did have a downdraft upon startup, some smoke came out the intake and I had the door cracked and some snuck out around there. I did feel cool air coming out of the stove when I was loading the wood so that should of been my first indication.. I guess I will run a heat gun up the flue first next time I do a cold start or even try a top down fire that I never have done. Anyways steelcat got right up to temp along with the stove and now it’s just doing its boring thing, outside the stack is clean, no smoke. I’m running around 3:00 on the stat and have around 400 degrees right above the cat. A mix of spruce, white oak, shagbark hickory and sugar maple. What a combo.
Looks a lot like how mine runs! Mine still creeps up to 700, but the difference now it doesn’t run away(so far) and comes back down slowly or holds with air mods. Haven’t seen 750+ since.Took a while to light the big ash chunk at the bottom, but stoves cooking now. 35 outside, 68 inside.
This stove would run to 700+ STT with any bit of air at all, but with the blower it’s very tame. I barely see over 500 with a full load.Looks a lot like how mine runs! Mine still creeps up to 700, but the difference now it doesn’t run away(so far) and comes back down slowly or holds with air mods. Haven’t seen 750+ since.
I cold start every fire and stopped overnight burns 2 years ago. I have to heat my chimney flue; I use a hairdryer as is seen in all my cold start photos here in this thread. I time it: 7min to heat the flue before torching and it draws beautifully every time.My insert gets little use( it’s on the opposite side of the house from my wood stove) so i always have ‘cold starts’ and downdrafts. I found using the heat gun or a hair dryer to heat the flue as you described gets the smoke going in the right direction. I tried just burning some paper at the top of the burn box but that didn’t always work. So the heat gun became part of the startup procedure.
