What Is In Your Stove Right Now?
Got some super cedars to finally try out. More crumbly than I thought they’d be breaking a chunk off but they surd work without kindling.
White pine is definitely a primo shoulder season wood. Burns real hot and fast and raises temp in the house in the chilly morning to where I don’t even need to fire it up at night.
  • [Hearth.com] What Is In Your Stove Right Now?
I've been using SuperCedars for probably 10 years now, maybe longer. I've found the trick to getting a clean break with minimal crumble is speed. Snap then fast and they break right on the line defined by your fingertips, and without going to fragments. I break them in the wrapper, then puncuture the stretched wrapper with a finger after the first half break. This keeps any crumbs that do occur in the wrapper, which I can shake out inside the stove after extracting the piece I want.
because I'll be damned if I don't burn those crumbs that I paid good money for
RealFeel is 1C/ 33F
59C inside is over the line
Free heat just cannot be beat!
My typical single split of chestnut with 95% Hazel and 5% white oak. A couple of the cats have been sneezing and getting treatment; fire really sorts them out
Anika hasn’t been sneezing, but she’s in the heat zone
I received the chimney chase cap on Tuesday and immediately installed it. Both stoves are ready for takeoff. Now we seem to be having a heat wave in the northeast so it looks like I will be waiting until Sunday or so to test everything out. 🤷🏻‍♂️
65 here in MD this morning. No burning yet. Rented aerial lift last weekend, used the Sooteater top down that went well, 6 solo cups of brown/black powder mixed with weed wacked stink bugs phewwww . It's been a very bad stinkbug fall....Was a little upset with that amount. But no flakes, just powder, the sooteater cleaned my Olympia Armorflex linerto bare metal . It had been 2 years since last cleaning. :( ......Rest of weekend I used lift to pressure wash upper levels of our houses siding and some upper level repairs. No more ladder work for this old geezer. Ready to burn, Temps look moderate.
Man, you're boring. Almost sounds like you're a Blaze King burner ;lol
(Just joking)
  • Haha
Reactions: ctreitzell
If only! Yeah, man, very boring…nevertheless heat is required and I hope I’m staying true to the subject of this little thread
I know, I will too, in a few weeks. Very boring, but posting when I reload
Happy burning!
21 outside this morning, loaded up a mix of Birch/Aspen this morning on just enough coals from a similar load last night.
We got dusted... Wife had a small load of pine, Aspen and black ash going when I got up.
I'm testing some red pine this year after seeing it's higher btu content in the charts. Wasn't very happy with white pine and firs. Noticeably better - definitely lasts longer.
Got any Jack Pine around there? As far as Pine goes I like burning Jack better than Red or White.
I don't think so. Round needles but way shorter than red or white pine, not flat like fir...?
One btu chart I have shows jack equal to red both well above white and firs, the other has it below red and closer to white & firs (and aspen).
I've been a little disappointed in the black ash. I burn it with the Aspen and pine as it doesn't last much longer. My first load last night one chunk of red pine still had form to it and the black ash was just a crumbled pile of coals like the Aspen but a little better...
Yes short round needles, branches every which way and small hard closed cones. Pretty ugly tree but burns better than the other pine I have around here.
Yesterday afternoon I found the cat protection plate of our BK down in the fire/coals. I wonder what happened there?
I wonder If I bumped it while morning loading? Or If I had a bit of an explosion in there? Glad it didn't smash the glass!
Reactions: AILDWarrior
It could also have slid left or right a bit during previous loadings (or even with thermal expansion and contraction cycles), and eventually had one corner fall out of the bracket. It only takes 1/4" or so of movement to get it that far that it'll fall in my system.
Fogged in most of the day
4C/ 39F outside with RealFeel at 1C/ 33F
15/59 inside and need the boost
Mostly because the male cats who were not vaccinated early in their lives have sneezy noses and they really love wood burning heat
Usual split of chestnut with mostly hazel, a chopstick and some skewers on some rotten cherry, oak and maple sticks for lighting
70/30 tonight. Seems like there is some legitimacy to the Super El Nino warnings. I've been burning all Fall but have to keep opening windows to keep the house temp under 75F!
Burning some spruce now that's been seasoned for 3 years and dry as it could be! Looking forward to some snow on the ground
Wow, I hadn’t realized your location before now…must be gorgeous up there :-)
Reactions: sixer
Alright, hanging out in the basement with the princess, (sshh don’t tell the wife) first ever light off of wood stove #2 and it went ok, the stove did have a downdraft upon startup, some smoke came out the intake and I had the door cracked and some snuck out around there. I did feel cool air coming out of the stove when I was loading the wood so that should of been my first indication.. I guess I will run a heat gun up the flue first next time I do a cold start or even try a top down fire that I never have done. Anyways steelcat got right up to temp along with the stove and now it’s just doing its boring thing, outside the stack is clean, no smoke. I’m running around 3:00 on the stat and have around 400 degrees right above the cat. A mix of spruce, white oak, shagbark hickory and sugar maple. What a combo.
@Dieselhead You got two BK40s now?? I do a top down every cold start. Wouldn’t do it any other way honestly
sig line says one King one Princess. Still, that's pretty awesome. One guy on this forum using more wood than me, other than those OWB nuts! ;lol
