Planning the ductwork to tie the Kuuma into my existing (propane) furnace ductwork. What slope/rise do I need, in order for the Kuuma heat to safely "move" in the event of a power outage? I found this for plumbing, but I'm now sure how it works for ductwork:
2 1/2" or smaller 1/4" per foot
3" to 6" 1/8" per foot
8" or larger 1/16" per foot
It looks like the main trunk line from the Kuuma plenum, to the (propane) furnace plenum, will be 21" x 9". This size seems to work with the clearances I have available, the width of the existing trunk (21.5"), as well as the 180-200 sq/in of volume needed for the Kuuma.
Will 1/16" per foot suffice? Total run will be 26'. 9' from Kuuma to wall, turn a 90, then 17' to the tie in at the existing furnace. The 17' run will be directly underneath the existing trunk line (too small to want to tie in to the end of the existing trunk...so I'll just run under it, and tie in near the existing plenum). I'm running on pretty tight clearances as is (keeping 1" between trunk line from Kuuma and combustibles after 9'...will have 6" from Kuuma to 9' mark), so I need the least slope that will safely do the job.
It's not ballsy at all on wood furnaces.....they are actually required on most.
