What to buy?
What to buy? Building a new Ranch in Eastern Maine and plan to put a new wood stove in the basement.
Never had a cat stove and don't think I want to make the change now. This will be my primary heat until
I get to old to do it anymore. Center of the basement with the stairwell close by. 1600 sq' above with a
full basement. Thoughts welcome. thx
3,200 sq ft is a large area. It may be better to heat with a high-efficiency wood furnace. The amount of insulation, window area, and building tightness will determine the heat loss. Has this calculation been done already? If so, what is the estimated heat load for the house? The basement walls should be well-insulated. Even better if the floor can be too, to reduce heat loss.
There are still large non-cat stoves made by Quadrafire, Pacific Energy, and SBI (Osburn, Drolet, etc.), though a lot of companies have gone to cat hybrids to meet the EPA requirements.
Heating from a basement presents challenges both for heat distribution and possible negative pressure. An outside air supply can help. Will the basement be a fully earth-encased or a partial daylight basement? Will there be a HRV installed in the basement?
Stoves are generally considered area heaters. Is installing the stove on the main floor an alternative possibility? That would open up a few more choices in non-cats.
I hope you have a walk-out basement. Moving wood for primary heat (to a large stove eating a lot for a large home) down stairs inside will get old quickly.
I think the larger the home, the more important it is to create an air flow circuit if the stove is going to be in the basement indeed. I.e. not only stairs for warm air upwards, but other place(s) for cold air to go down.
The reason is that having both go thru the same stairwell is going to create mixing/turbulence. That's going to limit the amount of heat going up.
A post of how I did this is here:
I find this made a huge difference. And the inline duct fan made that difference 10 times as large as natural convection through a hole I had made earlier (that hole was also not done right/fire safe/according to code, as it allowed fire or smoke to spread thru the floor).
Reactions: stovelark
Agreed- This would be a job for the biggest, baddest steel frame stove you can get for an unfinished basement. Quadrafire 5700, biggest Osburn or Drolet would be my choices. Dry firewood yet? Will this be a Class A metal chimney or Masonry? Centering stove downstairs is good, but needing to get heat to circulate upstairs is always part of the battle.
[Hearth.com] What to buy?
This is my layout. See the chimney chase in closet of bedroom #2. I'll face stove toward the living room/ kitchen area's. Class A metal chimney will be used. I've thought about cutting a vent in the floor in exterior wall in the utility room. Maybe mount a small fan under the vent to pull down the cold air for starters. If also need I may set up a box fan in basement under bedroom 3 area to help push the heat to the end of the house I want it. (south) I'll see how that does before doing anything else. The basement walls and floor will be insulated. Bedroom's 2/3 doors will be closed most of the time also. May have a walled in utility room in the basement on one end of the house. The center of the basement will be somewhat finished off as a TV room.
Begreen, no calculations have been done yet. I haven't considered an HRV yet. I really wanted a daylight, but wasn't able to get it (wife). Had one with my last house and loved it. I will have stairs from the attached garage down to the basement. Planning on pulling in the tractor with wood dumping it on a shoot that leads to a cart on wheel in the basement. Probably won't go as smooth as that sounds.
Stoves - I have a PE dealer down the road. I like the Summit LE and the Alderlea T6. Does the recent weld cracks worry anyone??
Stoverliker - Yes, I have read that too. Great information. Thank you. I do have some seasoned firewood coming next month. (and a moisture meter here waiting). Thank you all. Please keep the thoughts and ideas coming. I'll update as I go......
If the basement isn’t finished put the stove upstairs.
I've had stoves on the 1st floor and the basement. I understand that having the stove on the living floor is the most efficient. I will have an area finished off in this basement. Also, before I (most likely end up buying a generator) I can keep the whole house warm if I lose power for a long period. Also the mess it causes, the area it requires and the extra effort to get fuel to it. Basement it is for this guy. Thank you for your input though.
Reactions: stoveliker
Good to hear that insulation is going in the basement floor and walls. That will make a big difference. Will the upstairs walls be 2/4 or 2/6?
It looks like baseboard radiation on the plan. Is that for sure? If so, they should have done heat loss calculations. If this is to be hotwater heated, then maybe consider a wood fired boiler in the garage instead?
Thanks for posting the floorplan. That's helpful. It will be a challenge to heat evenly without ducting. I would also plan on an outside air duct for the stove. The Summit and Alderlea T6 have an air-break in the outside air connection to the stove, so reverse draft is a lot less likely. They are not prone to cracking. This can happen to any welded stove if something doesn't go right in production. It's not a common issue unless the stove is overfired. FWIW, our T6 will be going on its 18th season this fall.
Just for thought. Another option would be to put in a high-efficiency, EPA rated, zero clearance fireplace in the basement with the blower output ducted to the upstairs. Some of these fireplaces have the same firebox as their freestanding stoves. There are also wood-fired furnaces that have a large glass door and burn like a woodstove, but are ductable.
Regarding the oak, with the stove not going on an outside wall, how are you going to route the air line in the basement to the outside?
Regardless of the air break begreen mentions,. I'd keep the oak piping low (basement floor) as long as possible.
That would mean an elevated floor somewhere?
If the basement slab has not been started, perhaps it could be piped out of 4" PVC or ABS before the cement is poured.
