When I get them like that I stand it on end and split off the outside half of each trunk, from the top, with a maul or wedge. Then I whittle it down with the maul until what is left will fit in the stove. I usually get somewhere between 60% & 75% into clean splits. If I can't get it small enough for the stove then the remains end up on the uglie pile. I don't like to noodle it with the saw since the croch is usually full of dirt & grit that ruins my chain.
KaptJaq
Dont go past the middle though,fibers are too tough to separate without hydraulics.
I do exactly as KptJaq does, split it from the outsides in till the middle left will fit in my stove (I don't have to go far cause my door is 11x13"). Save the wear on your saw & chain, split it down.
Well that was certainly a poor cut when they cut the tree. If you have hydraulics then I'd split it right down the crotch then resplit each side. Easily done with the hydraulics.
I guess I should have found out how to cut the tree right first
, So what would have been the right way ?????Well that was certainly a poor cut when they cut the tree. If you have hydraulics then I'd split it right down the crotch then resplit each side. Easily done with the hydraulics.
Thanks found VidQuads has a video for hand splitting a crotch. Not sure it is accessible now, was on the old forum set-up
Makes it look easy.
He cuts his own wood though & his crotches are cut much better![]()
Thanks found Vid
So, I should have cut one "leg" off flush with the rest of the trunk ???
45 seconds? Want to buy a good chainsaw?If its most anything but Elm,a good strong hit from the maul about in the middle of each center usually does the trick,Dont go past the middle though,fibers are too tough to separate without hydraulics.But if it IS Elm or something else extra tough -Just like it sits there,right down the middle.Good sharp chain I could be through that in less than 45 seconds.
Using razor sharp full skip 28" chain & rakers lowered a bit extra.That's for ripping a 24"+ diameter super hard Honey Locust w/gnarly grain and or knots.Straight grain I can be through it in half the time.Dual ported muffler really makes it growl now.45 seconds? Want to buy a good chainsaw?
Gary
The quicker I get done,the quicker I can move on to other projects & get paid.45 seconds? Want to buy a good chainsaw?
Gary
Using razor sharp full skip 28" chain & rakers lowered a bit extra.That's for ripping a 24"+ diameter super hard Honey Locust w/gnarly grain and or knots.Straight grain I can be through it in half the time.Dual ported muffler really makes it growl now.The quicker I get done,the quicker I can move on to other projects & get paid.
