When to engage/close the bypass
It's like this.
A valve on a T that opens up once the suction (draft) is too high, letting in air from the room in which it is in.
Generally their trigger point setting can be set by moving a weight. (note that this one seems to be upside down...)
So they resolve high draft on the stove by satisfying the suction partly by flow through the stove and partly by letting in air from the room.
[Hearth.com] When to engage/close the bypass
Reactions: Tron
Reactions: Tron and stoveliker
I am curious about your thermocouple/probe setup. I'm not thrilled with the catalytic thermometer that Hearthstone provides as the blower tends to influence the reading quite a bit. Any information you can provide me? Thanks in advance.
Have you ever seen your cat thermo up in the "too hot" range? I have my alarm set for 1450* because they say cat damage can occur at prolonged temps in excess of 1500*.
Measure the thermometer length, then order the sensor for the Auber thermo accordingly. If you can somehow tell where the probe tip is in relation to the face of the cat, you want to bend/adjust so that the tip of the probe 1/2-3/4" from the cat.
