That was a Socratic inquiry on my part - I've owned a 1999 Dodge 3500 with a diesel engine since 2007 and my experience is as follows
- I get about 18-19MGP combined mileage and 24+ on the freeway. The same vehicle (1ton 4x4)with a gas powered v8 or v10 will get about half that mileage
- Upfront cost is more, but resale is also more, so that's a wash
- Diesel fuel prices vary in relation to gasoline but for most of the last 8 years it has hovered between regular and premium. With nearly double the mileage diesel would have to be nearly double the price to compete.
- The cost of maintenance is not a cut-and-dried issue. For example, my truck holds 12 quarts of oil, so oil changes are more expensive. But since my truck holds 12 quarts of oil they are also less frequent. Oil filters, fuel filters, air filters are all about the same price vs gasoline. IMO the only advantage for gasoline is the matter of catastrophic failure or repair: replacing a diesel engine coul
I have also been driving my 2000 Ford F350 4x4 with the international 7.3 diesel for about 7 years and 50,000 miles now and I record mpg on every single fillup in a book. I tow heavy, haul heavy, and also commute with it. Automatic trans, yuk, but manuals are rare. This truck weighs 7500# empty.
-My experience with maintenance is the same, no more expensive than gas.
- mpg when running not towing is very good, 15-20+ depending on distance traveled. 8 mile commute = 15 mpg.
- mpg when towing is much lower. You have to feed an engine to make it work. I return 11-12 mpg when towing 8000# of RV. This is reality on all diesels, look at the RV forums, when you work a diesel you need to burn fuel. Like a cat stove, there is no magic, btus must be burnt to do work.
- The gas version of my truck gets half the mpg and is much weaker.
- The only reason gas is better is that if something inside the engine breaks, it can be extremely expensive if you must use a mechanic to repair it. I replaced the water pump on Saturday and it was in stock for 135$ from autozone.
- I would love a manual trans on mine.
As far as I know the only new full size 4x4 pickup available with a manual transmission is the Dodge Ram 2500 with the 5.9L Cummins diesel.
They haven't made the 5.9 in a ram pickup for almost 10 years. They replaced it around 2007 with the 6.7 cummins.
So i think ?? the diesel overall might actually have more advantage at light load.
The biggest advantage is at light load. The advantage is still there at all times but especially when running empty for long cruises. We're talking a huge engine/truck returning the same mpg as a freaking 4 cylinder minitruck.
Another reason for high mpg is the very high compression ratio. High CR means a more efficient cycle. No throttle plate ever means low pumping losses. The diesel has more energy per gallon than gasoline. Low rpm operation means less friction.
