I seen one on a website for 1670 amarican bucks. its like 269 more for the big window. shipping free.[/quote]
what stove?[/quote]
I'm sorry the Maxx
what stove?[/quote]
I'm sorry the Maxx
enviro max sucker said:Hi all.
I paid $2499. Canadian for my Maxx. What a rip off.
enviro max sucker said:problems with this since December, when I bought it. Sherwood Industries still hasn't corrected the problems with this thing. I think it is going back, today.
enviro max sucker said:The Maxx goes back on Thursday the 21st. The dealer tells me that the Omega has its growing pains, too. I am going shopping on Friday for another stove, but I am not holding my breath. Probably going to make Esso richer for a few more years until these stoves get their problems ironed out.
hearthtools said:enviro max sucker said:The Maxx goes back on Thursday the 21st. The dealer tells me that the Omega has its growing pains, too. I am going shopping on Friday for another stove, but I am not holding my breath. Probably going to make Esso richer for a few more years until these stoves get their problems ironed out.
If I were you I would make the switch to the Omega and take advantage of the price you are getting it for.
Prices are just going up on stoves due to Steel prices and the weak American Dollar.
I have been using my Omega since Oct.
2 tons of pellet and only cleaned it out 1 full cleaning and 2 kind of fast dump the ash cleaning.
The only Growing pain my stove had was the Agitator was welded with the wrong kind of Welding rod
The send me a Cast iron one to replace the Stainless steel one.
I have had losts of stoves in my own home and even more in my Showroom
The omega has to be the easiest pellet stove to take care of.
No chipping out burn pots
No dumping the burn pot every few days
Ash pan will go for almost a ton of Normal grade pellets
Shelby said:I have to agree that the Omega is a great stove. I installed mine a month ago and it has run great since. Very little cleaning required compared to my last stove, Enviro EF3. My house is 5700 sq ft and the Omega is in the basement area and it heats the basement, main floor and upstairs no problem. We keep the main level of the house around 24.5°C. We have had some cold days and nights in Newfoundland since I have put in the Omega also. I haven't set it up using the thermostat control yet but I like the way the you can adjust the output. The large hopper is also great. We went away for a weekend for my son's hockey and we filled the hopper up on Friday afternoon and set it on a little above low. When we got back Sunday evening, it was still running. I was originally going to get the Maxx but they couldn't supply it until late February so I went with the Omega instead. I'm glad I did.
hearthtools said:any updates on how everyones OMEGA is doing.
they only problem I had was the Agitator (burn pot cleaner) not welded with the correct welding Material
but that has been fixed.
johnnywarm said:hearthtools said:any updates on how everyones OMEGA is doing.
Didnt that happen last year??
hearthtools said:johnnywarm said:hearthtools said:any updates on how everyones OMEGA is doing.
Yes and that is the only problem
I have burned almost 3 ton last season and did one cleaning last year in Dec.
and an annual service on it before my October start up this year
I took the the stove apart and cleaned flue, blowers and adjusted the Chain drive for the agitator (was loose so it made noise)
No other problems.
Im going to clean it today after i get home from work.
the wife has been home for the past 2 weeks because of surgery so we have been using it more.
The store demo unit has been doing great also.
we have only burned about 75 bags through it so far (since we installed it at the end of last winter)
because we burn other demos pellet units also
We keep the store Omaga full of pellets and set a Remote thermostat for it to keep the store warm when others are not running at night and when we are closed so our gas units that have thermostats wont come on.
westcafe said:I read the post about the omega heating 5700sq. with the stove being in the basement of a 3 story home, is this really possible keeping it at 24.5C? I can't get my home that warm and it's 2000sq. and only 2 stories! This is our only heat source we are using, is it theres? seems a bit out of reach.
westcafe said:I am running our stove without a thermostat and on Med. and we seem to be getting enough heat, but if I were to try and heat 5700 sq.' We would freeze. We need to run ours on a higher heat setting when it is really cold and we are only heating a small amount of footage compared to the 5700. Our stove is also in the basement as they stated there is. Wasn't saying it couldn't be done, just seemed like a lot. Maybe we are not running our stove efficiently.
flamegrabber said:Installed my Omega Feb 26. Remote t-stat running in on-off mode since the install.
Plenty of heat. Runs mostly on #2 and sometimes on 3, usually in the morning to give the house a quick blast of heat, then back down to #2. As an experiment I ran it on #4 when it was 15* out and got the first floor up to 80* in about 1 hour. My wife told me it was too hot and to turn it down.
I'm only heating about an 900 sq ft floor ( first floor of a 1800 sq ranch ) but it's quite drafty. The stove is in a 4 season porch that has over 200 sq ft of glass ( windows + skylights ).
Very low maintence and it throws plenty of heat and it burns many different fuels and the big hopper is great.
FG.
hearthtools said:flamegrabber said:Installed my Omega Feb 26. Remote t-stat running in on-off mode since the install.
FG.
can you say OVERKILL.
LOL
Good news I hear Enviro is in the works of making and EMPRESS cast iron style stove with the Feed system and Agitator burn pot as the Omega. at a normal 40k btu
they were going to send me a prototype to test. But NOW IM OUT OF BUSINESS.
I always clean my stove just before start up. Mostly because Im to bz working on other peoples stoves and problems.flamegrabber said:Rod,
I need probably 12-15k btu's to just overcome the draftyness of the room it's in. Besides I like overkill! And I like the low maintenence, multi-fuel, big hopper, etc. And the heat is just great. We come in from the cold and just stand in front of the Omega for about a minute to warm up. It's great.
Rod, what would you recommend for end of season maintenence?
I heard from a guy yesterday say it's better to just leave the stove after the burning season and not clean it until just before the next season begins. He said the ash content left in the stove protects it from corrosion, etc. Not sure if that's true.
I've also heard to clean it out and spray a coating of Pam in the firebox to keep the rust away, and to plug the exhaust with a rag, etc. There're too many opinions out there, hard to know which is best.
Also, I read a post of yours Re: your cleaning your Omega. You said you cleaned the flue. Does that mean the horizontal exhaust coming out the back of the stove or the vertical chimney/vent pipe? ( remove cleanout and run a brush thru the vent pipe dumping out the tee at the bottom, etc. ) I have a cleanout tee and about 12 feet straight up from that.
How long does your full cleaning take you? That may help me estimate how much time is required to do the job right.
Love the stove.
FG.
