Whitfield Profile 15+ years service, auger quit working so I took off the motor and put power, 120 volts, to it and it worked. I disconnected the pressure switch and got a little over 4 volts from those connections/wires, jumped the wires and still not working. Should the wires to the pressure switch yield 120 volts or is the 4 volts a control circuit and correct? Any ideas on what could be the issue since the motor works on the test bench?
a careful bend using two needlenose pliers (one to hold; other to bend) and back in business.
