My wife hates my wood insert and wants a gas fireplace in the living room. It's a Osborne 1800 is there any way to use a wood insert in a room that does not have a fireplace. Is there anyway I could use it in my sitting-room.
Hmmmm, +1Give us some sense of how attached you are to the wood stove versus how attached you are to the wife.
I mean, the fact that you are asking the internet about this gives us SOME indication, but refine it for us a little.![]()
You're on the wrong forum. This is a wood burners forum, not a marriage counseling forum.My wife hates my wood insert and wants a gas fireplace in the living room. It's a Osborne 1800 is there any way to use a wood insert in a room that does not have a fireplace. Is there anyway I could use it in my sitting-room.
That Oak & Hickory ain't no where near ready to burn. 3years minimal for those species if you want optimal burn from them.I did the installation myself last year full-length stainless steel chimney liner with insulation wrapped around it. Last year I bought wood and had some hickory Oak and Poplar that was 10 months old. This year the Hickory is 22 months old going on 24. I have a stovetop thermometer on it and it doesn't seem to get over 3:50 or so. The living room has never gotten hot as in over 7 2 degrees. At my other house with the big Jack furnace I was able to eat heat 3000 square feet to the point that you would open up a Windows
This is what I would except. Interior masonry fireplace. Even if the wood is perfect I would hope for more heat. Its been burning for over 2hrs still at 350 stove top. I could get some of that firewood from acme and see if that would get a hotter burn.Something has to be up with your stove. Guy I work with has the same insert in an exterior masonry fireplace. 16 ft stainless liner. Sits in a 500sqft living room in a 2000sqft house. It will almost cook them out of the room even when below zero outside. His has the blower on the bottom. Do you have that ?
But it's a metal box it should heat up.
Not true at all both can be ready in a year in the right situation. I agree with you the wood probably isnt dry. But it is certainly possible.That Oak & Hickory ain't no where near ready to burn. 3years minimal for those species if you want optimal burn from them.
Yes that means its clean.Just looked at exhaust from chimney. No smoke just that heat tremors. That should mean a clean burn?
