It must have been worth it, you got it. It looks like it will burn. Maybe you check the moisture content. Wait a year if you can I'd say.View attachment 171870
Cutdown some stone dead barkless austrian pine at work today. Was it worth getting or a waist of time? What are the chances that standing dead with no bark that this stuff will be dry enough to burn right now??
It kind of depends on whether you need it this season or not. If you need to burn it I would say its likely ok. If I had pine that was 22% mc I would re stack it for next winter but I have lots to chose from in my stacks. Mixing it would be a good option. I've had folks roll their eyes at me here when I say this but the readings on your moisture meter are not likely completely accurate and a calibration for pine (and some other woods) should be considered, so at a reading of 22% on your mm your actual moisture content is likely a bit higher. 20% I would roll with it because its close enough.Split a couple rounds that I brought in last night to check the moisture reading. Got readings 20-22. So this should be ok to burn right? Or would I be better to let it sit stacked and season. I just don't want to gum up my chimney.
I was hoping to mix this in with some hard wood I have that's not quite at 20% yet.
I wonder about this to @Wood Duck but with the blueish rings on those ends its classic pine beetle. Maybe other bugs cause the same discoloration?I don't think pines are normally killed by beetles here the way they are out west, and standing trees don't dry out as well here as they do out west. Still, I think those pines are ready to burn if they are at 20%
Yep, looks like the thousands of hectares of beetle killed pine we have around here. The blue ring is very predominant!I wonder about this to @Wood Duck but with the blueish rings on those ends its classic pine beetle. Maybe other bugs cause the same discoloration?
We take a lot of Austrian pine down b/c of this. Neighborhoods and developments that planted them back in the 70's and 80's. Wince its in one tree it seems to run wild from tree to tree.Austrian pine is particularly susceptible to Diplodia tip blight, a fungal pathogen. Austrian pine, especially stressed and weakened individuals can succumb to Diplodia .
http://www.extension.umn.edu/garden/yard-garden/trees-shrubs/diplodia/
Oldman is looking to start a fight!Even if cut with a Stihl, it might still burn.
