- Aug 24, 2007
- 113
Where are you at in Michigan. I just purchased my Pacific Energy Summit brand new last year for $1550. Im just north of Grand Rapids.
LHKountryboy said:The Hearthstone Heritage is a "pretty little piece of cast iron furnature" , suitable for occasional use, it is not a real source of primary heat, go buy a real, as in STEEL BOILER PLATE, welded stove for primary or secondary heat.. or DEKA wood Furnace at Menard's if you want to force air heat a house. You can get a Deka or similar "WOOD FURNACE" new for 700 or so, used for about $350.
I just picked up the same stove, same color, for 100 bucks, the fire brick is cracked on the one I bought, just like on that one. The cracks will fill with ash, its not a hazard, unless it is actually "loose" and readily can be casued to fall in the firepit. They didnt even have a "deflector shield" on mine, it never had one as far as I can tell. They ran it for 8 seasons without one either way.
Personally for $600 and pick up and install of that 600 plus pound beast, I'd say shop a little harder, personally I wouldn't have bought the one I have, but it was sort of a favor to family member, who wanted the "evil thing" gone. They are cute as a decoration, but I would NEVER trust a cast iron stove for any sort of safe heat source. Im going to use it for occasional use on my sun porch after I cut a cast iron grate down for it, to keep the coals OFF the poor quality cast iron "spin and dump" ash dump. No grate, what a silly idea.
To me its a rich man's "toy" or a ladies decorating accessory item, not a REAL wood burner. It is messy and not airtight, so expect smoke damage to your home and furnishings.. if you truely plan on using it, ask my relatives, 8 seasons of it and they gave up, replaced all their furnature and repainted the interior of their house. It cost them a lot to erase all memories of the Hearthstone, "one of the most romantic, beautiful and satisfying ways to heat your home. " according to the manufacturer.
I use an old Shcrader Dutchess Airtight with a smoke burner to heat my 3 bedroom Fairmont, its bigger, and its BOILER PLATE welded steel, with 2 cast brass doors and a fire brick lower box liner, I've ran the thing till the S/S stove pipe glowed ( my flue thermometer reads 1200 at that point, sure cleans the flue out nicely.) It sits on a 6 inch reinforced masonry hearth topped with slate and is backed by a 8'x10' solid "REAL"brick backer wall ( requires its own foundation, to hold all that up in a "manufactured home". BUT that is REAL thermal mass.
My Schrader ACTUALLY does burn for 12-14 hours, that Heartstone thing could.. I have both a in flue thermomter and a magnetic one on the outside of the pipe, and I hawk the thing. It runs 24/7 (except for occasionally glass, stove, and flue cleaning.) from Dec till March. It burns wood to a fine white ash.. and when its half full I shovel it out.
Been running it my Schrader for 20+ years and never had a problem, other than door and glass seals, which dop require occasional replacement. I run about 4-5 cords thru it in a cold winter and use about 100-150lbs of propane for back up in 12 months in my furnace and gas appliances. My 21 ton wood splitter and 3/4 ton 1967 Ford truck (oh and me) get a work out in the process fall to stock the wood shed, But this is SW MICHIGAN. And with the lake effect snow I get, I take no chances.
