At this point, take it. It's still cheaper than oil
Call me Dix, most every one else does ... or worse
Lol, ok Dix thank you for the info. I can get a full seasoned cord delivered for 180 not far away. But I have to see if its seasoned.
Hello dtdeh, thank you for that I know we're they are. I think they are a little expensive. Over 200 a full cord.
But if they have well seasoned wood I mite have to check them out.
Gotta say you are really stacking the deck against success. A poor flue, poor wood and perhaps the wrong stove combined have the potential to make for a bad experience. Maybe pass for now and look at ALL the options, including getting an easy breathing stove if this is really the only option for chimney location.
For your setup I think you might do better with a cat stove with no secondary manifold air. The Woodstock Fireview would be a good size. This is what Backwoods Savage is burning and it has worked well with his setup. A Buck 20 catalytic stove might also work if you prefer steel. Pacific Energy's stoves have a short secondary manifold that seems to breath a bit easier than the Nappys. I have a friend that has one on a poor chimney setup and it gets a decent secondary burn, but not nearly as good as we get with a straight up chimney.
Sounds like your course is set. Adding some extra pipe up top and bracing it may help. Try to pitch the horiz. run up 1/4" per ft. and watch clearances at all points, especially at the tee.
This is not a matter of stove size. It is more a matter of how the stove breathes. Stoves are not all built the same. Some have long secondary preheat manifolds and others are shorter. Some cats have no secondary air feed at all. Draft is the engine that drives the stove. Dry wood is just the fuel.
What will the total vertical rise be from stove top to stove cap?
BG is like freaking Obi Wan Kenobi
**apologies in advance for the hijack**
Which makes me wonder . . . which hearth.com member is Yoda? Han Solo? Chewbacca? Princess Leia? Luke Skywalker? Darth Vader? The Emperor?
I think I would make a fine ewok.
That is easy enough on a rake edge, but he is running at the eave. Can't just cut that out and the gutter etc. Ain't gonna work without being a PITA and looking quite awful.Treemoss,
I would lose the 2 thirty's at the top, and cut a hole in the roof/sofit, and go straight thru/up. Two reasons, one is for better draft, straight pipe..., but more importantly, for strength. A support box going thru the roof will hold much better than the two 30's passing around the gutter.
Ask me how I know this? Ok, since you ask, because I did the exact same thing you are about to do, but for my oil burner chimney. It lasted 3 weeks and the top blew over/bent/broke. They came back and re-did it thru the soffit and its 2 years later, and 2 hurricanes later (Irene, Sandy) and its still perfect.
Also for looks. He can box it in with a chase, and look less ghetto.Treemoss,
I would lose the 2 thirty's at the top, and cut a hole in the roof/sofit, and go straight thru/up. Two reasons, one is for better draft, straight pipe..., but more importantly, for strength..
Yes it has been split for that long nice and gray with lots of cracks
Short bed: 6.5' L x 5' W, would need to be stacked as a cube 4' high to make 1 cordNot to mention that many dealers definition of a "cord" is a pickup load
I dont care if its cat non-cat all I want is to make sure I have a good draft and a proper running stove. I don't want smoke issues and bad Creosote problems.
But I feel I'm going to have problems with my offsets and 45s and I'm thinking maybe I shouldn't put in a stove now.
