Ashful
I get 24 - 30 hours on a full load of oak in an Ashford 30.1, with the fans running on a very low setting.  I've never tried running the fans faster, since I find them very annoying (loud).
			Actually, the fans are mounted to two skids (sleds) that can be pulled out and serviced while the unit is burning if needed. The thermostat sits under the firebox, at the front of the unit where room air provides plenty of fresh air.The Princess thermostat is on the side, the 25 thermostat is on the bottom alongside the two fans (but not behind them), I am interested to see how the 25 thermostat works with ash on the bottom of the firebox, if that throws it off any. Fans need to be run at the same speed as the thermostat setting (low,med,high).
I always use OEM gaskets; They are the right size and density for the application.Ok, I went to my BK dealer to buy some door and bypass gaskets. They tried to sell me Meeco gasket and were guessing what size based on visual appearance. Please tell me I can order direct form BK!!
Pretty please!
All combustion and related products must be purchased through authorized dealers.Ok, I went to my BK dealer to buy some door and bypass gaskets. They tried to sell me Meeco gasket and were guessing what size based on visual appearance. Please tell me I can order direct form BK!!
Pretty please!
Pretty please!
Haven't heard them side by side but our PE fan is pretty quiet too, especially on low speed.There is a low frequency hum on low. ..but vastly quieter than other fans.
We installed our first Sirocco 25 yesterday. The sled mounted fans were very cool! The flue collar design is very innovative as well. Pretty sweet piece!Actually, the fans are mounted to two skids (sleds) that can be pulled out and serviced while the unit is burning if needed. The thermostat sits under the firebox, at the front of the unit where room air provides plenty of fresh air.
How much less of a burn do you get with the fans running?
I've been sure to keep my fan matching the thermostat setting. When I flip it down to low the fan goes down also.
I know I'm not going to get burn times anywhere near what a freestanding stove gets, but I'm more hoping to get a longer burn than 6-8 hours.
Years ago we made a gas ZC unit that required nearly complete dissection in order to replace the fan. I was at a shop when a dealer handed me a few tools and said "show us how to take out the fans." 2 hours later!!, I had the old fan out and new one installed.We installed our first Sirocco 25 yesterday. The sled mounted fans were very cool! The flue collar design is very innovative as well. Pretty sweet piece!
Isn't the Ashford 30 slightly larger than the Princess? Did you mean the King?FWIW if my wife had OK'd the aesthetics I would have gotten a bigger stove, at least a princess. In full on wintertime mode with the distillation unit making clean water for the humidifier, and the humidifier running, and the box fan down the hall supporting the convection loop, the sound of the fan kit on the stove is pretty minor.
Yes, my comment was not directed at anything unique about BK fans. I just hate to hear fans humming on any woodstove.There is a low frequency hum on low. ..but vastly quieter than other fans.
Ashford 30 is ever so slightly smaller than the Princess.Isn't the Ashford 30 slightly larger than the Princess? Did you mean the King?
The hum is only there when running at low speeds. At higher speeds, the hum is replaced by the sound of rushing air, which is to be expected.Electrically commutated motors (ECM) can be completely hum free. Shaded pole motors will produce varying degrees of hum and "sing" depending on the speed setting. It was so bad on my last (non BK) stove that I never used it. Hum can also make bothersome sheet metal rattles. It would be nice if BK would look into using these as it could make a nice improvement to fan usage.
Seems a silly statement to make, unless there are other stove manufacturers with shaded pole motors. I don't think there are.If BK does switch over, I will make a purchase. Why does low have to be noisy?
Right you are. .1 cu ft is a negligible difference.Ashford 30 is ever so slightly smaller than the Princess.
2.75 cu.ft. vs. 2.85 cu.ft., or something along those lines (from memory).
I'm living in good times, here. More oak than I can find time to process, the last few years, and craft ales in every bar! Neither will last forever.Oak doesn't grow up here. I suspect if I delivered a truckload of spruce to Ashful in PA he would make sniffing noises.
We burn oak for campfires around here!I'm living in good times, here. More oak than I can find time to process, the last few years, and craft ales in every bar! Neither will last forever.
How about some pictures of a Blaze king with full load of wood getting ready for a 8 hour overnight burn. Could you post a detailed time frame of events like fan speed,cat probe temp,Top stove temp,outside average wind speed? I have an insert and still learning here so post some pictures!
