What stove model, Jeff? I also suffered some broken bricks in the rear wall of my Ashfords in the first year. I don't toss wood in, either, always thought I placed it in there fairly gingerly.
I have an Ashford 30. This is my first stove; how do you guys suggest cleaning this thing?
The general concensus here last year was a combustor lasts about 10,000 hours in the active zone. Works out to two winters for me, i should be good this year and buy a spare next summer.
I will answer each person in turn as I don't know how to " multi quote" if that even is such a thing. I apologize for not answering everyone until now. My wife has been quite ill for sometime now and I get to helping out around the house and one thing leads to another and it is bed time for me.Did you inspect when new? I am wondering if that has always been that way or if this is new after this season.
I want to vacuum that myself but I am scared I will damage it. It seems very fragile? would I be better off with some bursts of compressed air? Cannot even imagine the mess that would make though. If I do vacuum what do I use ...like if I touch it wont it crumble? I agree it ought to be cleaned out some. What is your method?You're going to want to vacuum that cat out too. It should be clean, more exposed catalyst is better. I've never seen damage on the back of the cat. Broken bricks, yeah I've got one too on the side. It took me like 5 years though!
That is possible I suppose I get busy and I may? have forgotten but I set a timer for 15 min when I am getting it hot so I don't forget to go check on it. I especially asked my wife for a digital timer for Christmas last year for just this reason.I think you're good to go. High exit temps on the combustor don't usually manifest in this form, cracks can be normal. This looks like thermal shock. Is there a chance at all the bypass plate was left open for any period of time more than reaching "active"?
Yea I gather you burn a lot. I don't know really how many hours I burn here. We have a fire maybe end of October a few mid November and pretty steady by late November through till 1st or 2nd week in April.The general concensus here last year was a combustor lasts about 10,000 hours in the active zone. Works out to two winters for me, i should be good this year and buy a spare next summer.
I'm at about 6000 burning hours per year. We're not as cold as you in AK but we're cool for a LONG time. I expect two full years of cat life with no attention but after a vinegar bath I think I might get a third year from this one.
Some manufacturers say 12000 so a range of 10000-12000 hours seems to be far more realistic than 10 years! which would only work if you are using your stove occasionally for ambiance.
whoops I forgot to answer you. It is a 2015 Princess free standing w/ blowers.What stove model, Jeff? I also suffered some broken bricks in the rear wall of my Ashfords in the first year. I don't toss wood in, either, always thought I placed it in there fairly gingerly.
Like I said or maybe did not say? I have never had a cat stove before my last stove was a 1986 Old Mill that was the newest stove I had ever owned. So they could have said 25 years and I would not have batted an eye. I just knew that the stove had one and they do fail so I asked and they said 10 years. Please do take a moment though and tell me how to " safely" clean the cat without breaking it.
Sure, I've cleaned my cat a few ways. Yours is ceramic which means the holes are quite large and easy to clear but it also means less surface area so it is even more important that the cat is clean. The catalyst is actually pretty durable. Do not try to shove anything into the cells to clear them.
1) Low pressure compressed air blowing into the cat so the junk blows into the closed cat chamber. You can use air-in-a-can or very low pressure air (20-50psi) to blow out the cells. Close the bypass and have the chimney on and there is no mess that will go into the room. I like to add a small piece of rubber automotive vacuum line to the air nozzle to really shoot out each cell. Regulate that thing down to very low pressure though. It doesn't take much. Imagine that you're trying to shoot a spitwad just barely out of a straw, not trying to shoot it across the room. Puff puff. Low velocity.
2) Sweep the face of the cat with a paint brush. You can sweep the face of the cat with a new, soft bristle, paint brush just to clean the face but the junk in the cells needs to be blown or sucked out. This brushing is only really helpful with surface clogging.
3) Vacuum the face with a shop vac. I actually remove the hard plastic wand and hold the soft rubber hose up against the cat face to suck the cells clean.
Some folks combine #2 and #3 by using a soft brush attachment on their shop vac wand but I really want to put a suck on those cells. If, by sucking on the cells, the whole cat collapses into the shop vac hose then it was trash anyway.
Ps. How do I answer without quoting every persons original message ? I don't have a "reply" option only " reply with quote " option ???
Hit the "+QUOTE" link under each post you wan to multi-quote. Then under the place where you type at the bottom of the page a "Insert Quotes..." button will appear. Click that, insert all of the posts you had selected, and type away!Ps. How do I answer without quoting every persons original message ? I don't have a "reply" option only " reply with quote " option ???
For the all vertical flue above my BK I use a sooteater. The junk from the flue all falls down into the stove. Clean out that junk with a vacuum. Then remove all other debris from the stove with the shovel and then clean up with a vacuum. Don't forget to suck on the cat so that all debris that has settled inside the 2" thick cat element comes out. That's pretty much it for cleaning. You can check the door and bypass tension too.
Are you looking for info on cleaning the glass? The outside of the stove? The flue?
Thanks for the info. So, just to be clear, with an all vertical system and the bypass open, all debris from the flue will fall into the firebox where I simply shovel it out of the firebox? I was worried there would be some sort of lip or something that it could get hung up on. I also am curious about what you prefer to use for the glass and the outside of the stove.
One more question/concern. Occasionally, when I start the stove up from cold, then engage the bypass when up to temp, the stove will start to emit the paint curing smell. It appears that it occurs at the very bottom of the flue just above the stove because that paint has turned slightly lighter than the rest of the black chimney pipe. This has never happened when closing the bypass after hot reloads, only when starting up from cold. I was thinking that maybe when my stove is dying out that I'm getting some sort of accumulation. Then, that accumulation burns or melts off once I close in the cat on the next burn? Has anybody experienced this or know a likely culprit?
It is so much easier to just go up through the inside of the stove and straight up the flue collar. Tape a sheet of plastic over the stove door and cut a slit for the sooteater.This is what i am planning to do. I get at lowes a wye pvc fitting 6 in in diameter. i will connect it to the support box, one side of the wye will be connect it to a shop vacuum and the other port with a lid and a hole for the soot eater.
