If it is real hot air the rising heat from the stove surface will disturb the smoke. A comfortable medium setting. If you have a flue probe, try to hit 400. That will give a good strong draft.
okay, will do. any advice for things to be on the look out for that might indicate the need to replace the gasket? i've ordered a couple spares to have around the house for when the day comes...
how's the door gasket on your stove? turns out mine was quite off-centred in a few places, which is what is leading to my smoke smell i think. getting some new stove rope and will be re-doing the door. and this was on a brand new stove. hope it helps.
Will a vinegar bath help my ceramic cat ??
Mine is 2 1/2 yrs old and not getting to same temp as last season..
I'm totally fine with that though, I just ordered a new one..
....I had a 2ft section added to the chimney and wow, what a difference. Thought all was good. Smell was gone and even thou I never had a problem keeping the cat active it became much more stable...
That's good to hear that adding a 2' section improved it a lot for you... Mine's a comin' in the mail
here it is after the fire burned out. looks like it just got nudged out a bitIf the cat has lots of slop or keeps falling out then I would consider gasket replacement. It sits pretty vertical and ought to stay put. Some yahoos even run without a gasket!
ya, mine shut nice and tight too - passed the dollar bill test, but upon further inspection, the rope was very offcentered in the tope corner on the hinge side, so there was really no rope for the door frame to cut into.Thanks! The door gasket looks good to me. No indication of leakage, it is centered where it contacts the front of the stove, and the stove still shuts fairly tight. I haven't done the dollar bill or similar test yet, but if adding more chimney pipe and replacing the ill fitting stove/pipe adapter doesn't resolve it, then I will be looking very closely at the door.
can you tell by these kinda crappy pics if that's too much coming out of the chimney?
Question related to smoke smell, and how to avoid running on the "ragged edge of design parameters":
For the same stove, chimney system, outside air temperature, wood, etc: For the sake of this conversation, let's say I get it started, close the bypass when the cat meter reaches 10:00, load it to the gills when the cat reaches 12:00, close the bypass, run it for 45 minutes, and then slowly damper it down for the long burn after the meter has reached 2-3pm.
Will the optimum damper setting for the long burn be any different if I had only loaded 1/2 stove of wood (instead of full up)? Does a large load of wood require a higher damper setting, for example, because more burning wood requires more O2? Or does the large load of wood simply create more draft and suck more O2 through the inlet with the damper set the same?
you betcha! got it nicely tucked back in place this morning, never to happen again. thanks for the advice!Yes, it happens. Push on the metal tabs to reseat it evenly. Probably a one time thing.
The optimum thermostat setting is how warm your wife wants to be.
The max output of the stove is limited by the cross sectional area of the smallest portion of the air intake, and catalytic capacity. If your wood is too dry, down under 10 or 11% MC, burn rate will still be limited by the airflow through the intake, your combustor will be at max handling and you will see black smoke at your chimney top. Making more smoke than the combustor can process you are.
The "real" ragged edge for max output is getting from a cold stove up through active combustor to the top of the active zone and deck fans running on full output in the shortest amount of time possible. Once you are at max output, you are at max output.
The other side of the same coin is going for the longest possible burn at the lowest possible throttle setting, ie minimum BTUs per unit time. If you wanted too you could light one stick of incense, stick it in the stove...
You somehow managed to close the bypass twice in this regimen. I can't do that on my Ashford. I downloaded the manuals for both the Scirocco 20.1 and the 30.1...
In cold weather, fill the box with wood on your hot coals. Leave the door cracked open maybe 20-60 seconds to let all the fine wood hairs on the surfaces of your splits burn off. And the cat hair, and whatever other junk is one there. While the surfaces of your splits are blackening your load is making a LOT of smoke, but once everything is lit all the surfaces of your splits are more or less flat, close the loading door because now your load is charred. Charred and with the loading door closed, as soon as the combustor indicator is in the active zone, engage the combustor. Run it on high 20-30 minutes, and then set the tstat knob for how warm you want your house to be.
If your fuel is under 20% MC and you ran your charred load on high for 30 minutes you shouldn't have to fool around turning the stove in stages unless you are going really low. Once your 30 minutes is up, just turn it down to half in one go. If you want to go lower, come back ten minutes later and turn it on down to 3/32nds swoosh or 1/16 swoosh or whatever. With a good 30 minute burn on high and fuel that started at 20% MC or less turning the Tstat down is not a chore.
The Tstat setting defines how much heat is getting into your house how fast. If you run half a box at full throttle it will last half the time as a full load would have at full throttle.
If you set the Tstat at say half throttle, it is going to let about the same amount of air in, and put the same amount of heat out whether you have one stick in there, half a box, or a full box. The smaller load will burn away faster is all.
Thanks for the reply..I boiled mine this year- it was about dead after after 2 years and 9000+ hours. It is better and I feel like I might get a third season out of it (it's heating the house right now, so I got at least part of a third season anyway).
I built a cinder block rocket stove outside and then used the cinder blocks to make a new woodpile when they were done being a stove.
How did you get the thermal cracking so I can avoid itThanks for the reply..
Once the new one shows up I'm gonna give it a try..
Mine has a lot of thermal cracking (my fault), so I dunno if it'll stay together or not ??
And my reason for asking the question, is the simple fact that I get noticeable smoke smell in the room when I damper down a fully loaded stove, and none when it is a half loaded stove - with the same tstat setting, for example 4 PM on the tstat dial.
By reloading on a hot coal bed without bi-passing the CAT when opening the door.......duhhhh,...lolHow did you get the thermal cracking so I can avoid it
Sent from my XT1585 using Tapatalk
First season with the Blaze King so I'm learning toBy reloading on a hot coal bed without bi-passing the CAT when opening the door.......duhhhh,...lol
I grew up heating with a wood stove, I read the Manuel several times, I guess that part did'nt sink in ??
As always, what’s your chimney setup? Wood quality?Well, here's my first post. My wife and I are the proud new owners of an Ashford 30.1, and for the most part, love it. We agonized for months (we don't do anything without months of research!) over it and the Alderley T6. She really wanted the cast iron, I wanted a big stove for long burn times. Through numerous twists of fate, ie.,production issues at PE, and at BK, we found an Ashford in stock at a shop in northern BC and had a friend deliver it to the Island(he was coming for a visit anyway).
Although skeptical about catalytic stoves, we were convinced (through much reading of this forum/thread) that the ability to turn the Ashford to a simmer was a big plus, and the price of a cat every three for four years pales in comparison to $600 power bill we got the other day... and all my wood is free!
The room the stove is installed in is only about 350 square feet, but the rest of the house is sprawled over 2400 square feet. We've been burning for seven days now and the "stove room" doesn't get much above 23C, yet the rest of the house stays at a constant 20/21C - even the back bedrooms and bathroom stay at 20C and that's with overnight temperatures of -5C to +6C during the day. So far I've only been burning dry d-fir branches of 1.5 to 3 inches in diameter and have no trouble getting 14 hour burn times - can't wait to get into the big stuff!
Now for the "not so great". We have "smoke smell". It appears, like a few other owners on here, that it's coming from the top left/hinge side of the door. It seems to happen after I turn the stat down, usually to medium, the flames disappear and char is finished. This annoys me greatly. I love the smell of smoke on my salmon, charcuterie, and my bacon, but NOT in my house. I've burned wood for many years and have never had the smell of smoke in the house, even when reloading.
So, this is what I've done so far. I've read all 1308 posts of part 1 and 594 of part 2 of this thread to help me trouble shoot this problem, so I've done all the tests everyone suggests, check draft, add chimney height to 17 feet, paper pull test, I've even turned on all the exhaust fans(about 590 cfm total) in the house and can't get it to back draft.
I shut the stove down yesterday and removed the cast cladding and looked for bad welds like one owner had here. What I did find was one of the bolts that attaches the door "limiter" was too long and was hard against the front inner plate of of the stove, pushing the cast front on the hinge side out a bit. I've cut the end of the bolt off past the nut. I inspected the gasket carefully and it appears that smoke may have been seeping past the gasket on the hinge side - where the knife edge of the firebox presses on the gasket is shiny silver/grey, on the hinge side there is a hint of brown for the length of the gasket on the hinge side. I've also adjusted the door a bit tighter on the latch side, but unfortunately there is no adjustment on the hinge side(unless I grind the mounting bosses off a bit!). Put everything back together. I've run two loads since yesterday and I STILL have the damn smoke smell.
The best solution I've seen so far is replacing the gasket so it doesn't look like the dogs breakfast that it does now, and maybe "upgrade" the gasket like @kf6hap did with the Rutland gasket. But really, should I have to do this on a new stove?
I've got pictures if anyone's interested.
Steve
