All done, got about a 12oz of fine black powder, I'll called it the baffle but meant by-pass chamber, everything looks good to go.Baffle?
I just smile when his wife tells me she has to reload it every night when she gets up to pee.
![[Hearth.com] 2018-19 Blaze King Performance Thread Part 1 (Everything BK) [Hearth.com] 2018-19 Blaze King Performance Thread Part 1 (Everything BK)](https://www.hearth.com/talk/data/attachments/236/236409-6d060e46b51a62c585ebbe7c228526d6.jpg?hash=cVuQe9LJ0R)
View attachment 236390 I am back at the lake playing with the Princess. I started this load at noon today. Will see what it will yield.
I guess heat and ashes. Next question!
I'd take the door off (it just lifts up) and lay a straightedge across the back of the door and the gasket knife on the stove at various points to see if they are both flat.
The adjustment for the door is in the latch, which is adjustable. Overtightening that could conceivably make a gap on the left side worse.
Are you sure the replacement latch is defective? It is meant to have a range of adjustment, so getting a new one that is loose sounds quite normal.
(Also, check the instructions for your moisture meter. The readings you are getting are very unlikely, but that is not relevant to the smoke smell.)
@aaronk25 came up with a theory that with a tall chimney and high draft, air flow from the air wash may be altered causing smoke to be pushed against the upper area of the door and smoke could escape there.
I think it was touched upon at one point, but I don't quite understand how this can happen even at low draft settings, which apparently it does. It seems to me that while there may be potential high vacuum at the flue exit, a low draft setting would only allow air to come in the air wash at low speed, and it would move down the glass in the same manner as it would with the draft more open on a shorter chimney with the correct draft.
At any rate, you can either get a manometer to check your draft and make sure it is within spec, or just go ahead and install a key damper into the connector pipe above the flue exit and see if that helps.
@drhiii what about taking paper and taping it all around the door gasket and then taking a pencil and hitting the knife edge with the graphite and then closing the door to see where the weakness is, the heavy spots should leave a darker line on the paper.
Have you tried loading it up and letting it burn on high for an extended time? I once had a smoke smell for awhile and after much investigation believe it was the gasket wicking the smell into the room.I burn a lot of compressed sawdust logs and a few times they have fallen into the glass as they expand.As they sit there and burn down against the glass and early on while the gasket was not as quite compressed the smell would be there.I know its a long shot but you are asking for any ideas,well burn a good load or two to obliterate anything possibly sitting on the glass/gasket.Maybe you need the gasket to compress a while instead of changing it all the time.
I feel feel for you sir, I must be a frustrating experience and I hope you stay with it and get her going. Now did you check to see if your wife stuffed a rag in the chimney like the other fellow who was having issues?
What are the temps there?
Not boring at all.Most everyone is here to help, or at least try to.Yessir... I have run periodic high burns to try and manage the creosote buildup. And yes, am mindful of how I load wood. I always leave an inch or two in back to allow for air flow to circulate along the back of the stove and along the top. And am mindful of loading to reduce wood falling onto the glass. Have been pretty diligent about that.,
And I appreciate your ideas yes. On the changing the gaskets... the original door came on the new stove. It stayed on for what yes, would be a burn in period. The original stayed on for two months before I attempted the first reinstalled gasket. Each subsequent gasket replacement remained in place for a month. This last one is on a replacement door from BK.
Tx for the continuing ideas. I know this is boring for this forum. Just am trying one more time to come at this.
I swept my flue today for the second time this season and brushed the cat a little.
This is my third year burning with the original cat and have been seeing a good amount of smoke this year so its been making me nervous.
Even with that,I cant really say that I have all that much creosote.I expected much worse by the looks of the smoke but so far I guess the cat is still doing its job.Is burn time as good an indicator as creosote is for realizing its time for a new cat?
My burn times are still good and it stays active,just smokes a lot and I'm sure the cat is close to that 10,000 hour mark.Have any of you ever had a moment when you knew it was time or is it just a long gradual decline in performance?
Interesting.When mine have died it was rather sudden. I was in denial over the last couple of months because I could compensate somewhat by increasing the thermostat setting. That reduced burn times but made more heat and cleaned up the smoke a little.
Then when you finally break down and replace the cat you feel dumb for suffering for so long. The new cat is incredible.
where did you find that highbeam, I looked on codars website and found a 3cx-2 2 inch probe says its for some BK models
Would you accept 65-70? Zero may take a bit of work in here....As long as the cat meter reads “zero” when cold I believe it to be functional. I replaced my oem cat meter with the condar equivalent that has numbers. Numbers are fun.
