picked up a used 25 pdvc stove and everything on it seems to be working except the upper auger. I have power coming from pin 3 of the Board to the motor and continuity through the vac switch and continuity through to the motor. I plugged feed from the Lower auger into the upper and the motor spins. I jumped the vac switch and still nothing. In diagnostic mode I can get the upper motor to spin and if I hold down the “on” button it will also make it spin. It’s a 2005 model with no hopper safety latch. Thank you.
? Thanks for the reply and info.
