Hello, maybe one of you guys can help me
gain some wisdom by not making a mistake first.
What do i need to connect a 6 inch diameter tee snout to a 6 inch black stove pipe?
At first glance I thought I could just put the male end of the stove pipe into the tee snout but they are exactly the same size.
Do i just force the male end to be a little narrower or is there a specific adapter?
thanks and oh!
Which way is the correct way for a stove pipe to run? Joints running towards the stove or the chimney?
At first thought I thought I would want them running towards the chimney so the smoke has less chance to leak out the seems
but then I saw someone on here say you want it the opposite way so creosote doesnt drip down the joint/seam.
Thanks again for the wisdom!
thanks and oh!
