Golfeur
Burning Hunk
wipe your fingers on the stove or heat the place out and if your fingers are dirty is that the dust comes from. I suggest you seal all pipe joints and tee cap
Do you use a conditioner in your humidifier water ? You can get a powerdery mildew if you over humidify. Especially from mister types. I use and evap type and use conditioner and have had no issue as yet.The dust is gray/white. We've thought about the fines, but we are pretty careful with that. We definitely have some issue with that, but I don't think it's the main problem.
We have been running the humidifier in the one room to test, but we had to turn it off because it was getting too wet in there. It's a small room! There was a big dust/humid cloud but then after it all settled, there was no dust anywhere in the room that I could see. What's the deal? I so want that to be the issue!!
We had the stove and venting cleaned well once in the middle of last season and once at the end. That didn't really change the dust. Like someone else said, we might look at replacing the filter on the Ash Vac because I feel like I can smell ash when we run that thing. But we did get a hose to vent it out the window.
I don't speak French, but am willing to learn...The solution is obvious. Hire a French maid.
The obvious simple answer is either the vac is leaking or your stove exh system is leaking and being sucked through the stove by the convection fan and spread over the house. Start by starting the stove at night and with the lights off shine a flash light at every joint in the exh system starting at the stove and working your way toward the wall or ceiling where ever the exh pipe goes. The other cause is a leaky filter on your vac. Try turning it on and as you are cleaning shine a light around it looking for soot in the air. Most of the time the joints can be sealed by either high temp tape or high temp silicone smeared over the seams and joints of the exh pipe. Often the installer will not do that on the joint between the stove and rest of the pipe and that would be my first place to lookOk. thanks for the feedback!!
How do you seal the venting? They take it all apart when they clean it.
Hi Rona I mentioned the same thing for the pipe of the stove in a post from the beginning and also a way to check in another post and there is still no response. Looks like looking much more complicated than what was
Filter ordered!If it was that humid in the room, the dust may have gotten carried out by evaporation / the humid air -> equalizing with the dryer air outside the room. Please post the Brand name and Model # of the humidifier, so we can check what (type) it is / provide better feedback to you.
We have 2 humidifiers. Both are ultrasonic.
One is this one: http://www.amazon.com/Bionaire-Ultrasonic-Filter-Free-Humidifier-BUL7933CT/dp/B002MYZFKC
and the other is the little Crane 1 gallon one generally used in kids rooms.
Getting a new filter for the ash Vac seems like a logical, low cost step.. ( Amazon has them at a good price. )
. . we aren't really finding much of the dust downstairs... It is all upstairs mostly. . Or maybe it is the humidifiers since they are all upstairs.
