We took out an old non-venting propane fireplace to be replaced with a Jotul F45 Greenville. I have a professional installing the stove itself, but I'm building out the alcove myself to receive the stove later this month.
I'm hoping for some input and validation on my ideas on this installation.
I've done the demolition as shown.
I'm planning on replacing the old insulation with new rockwool batts, lining the alcove with durock against the 2x4s on the sides and back, and installing a 2nd layer of durock on the back with 1" ceramic spacers and an opening/gap top and bottom on that back durock/tile board for air flow/heat shield. The entire alcove will have 12"x12" slate tiles, leaving of course the openings on the back wall for the heat shield. The hearth will use 8" cinder blocks (to raise it up from floor level for appearance and easier loading) and durock with slate tile.
I believe with this 2nd layer of durock on the back, spacers, air space, and tiles, we should be able to install the stove 7" in front of the tile on the back wall. My width on the alcove, from combustible 2x4s, is about 52", so I think we're good on the width with not having to have heat shields on the sides.
Does this sound like it meets the spec for heat shielding to reduce stove spacing to the back wall?
If I have the cinder blocks/durock/tile on the heath under the stove, do I need a bottom layer of durock below the cinder blocks also (between the wooden floor and the block)?
I am planning on installing an outside air feed through the hearth also… Pretty sure that has no bearing on the clearances questions.
This manual is what I'm relying on for my dimensions to combustibles. https://www.jotul.com/sites/usa/files/products/139967_Rev C_Manual_F 45 V2 - ENG (shrunk).pdf
Having not done this before, please share your wisdom with me!
Thank you.
![[Hearth.com] Advice on pending Jotul F45 Greenville Alcove Installation [Hearth.com] Advice on pending Jotul F45 Greenville Alcove Installation](https://www.hearth.com/talk/data/attachments/298/298811-2c6509242362b9d241a7f907dca87524.jpg?hash=79N_utHfgu)
Thank you.
