Jotul Greenville Installation
RI_FL_Line
38
Rhode Island
Last fall I had a Jotul Greenville stove installed in my fireplace. The installer left the flu collar in the top exit position and had a hard time connecting to the existing liner but finally got it done. I have been happy with the stove but after installation I read a bit more about this stoves installation and I would have preferred he used the rear exit flu collar with a tee pipe to making cleanings easier and this would also allow the stove to sit further out on the hearth. He came back recently to do this but left with my stove disconnected as he didn’t have the required tee part. His office emailed me a few days later and he said his supplier does not make a 5 ½” liner tee with a 6” snout to connect to the stove so he could not do what I wanted. He said he could give me an estimate for a new 6” liner which will be expensive. Reading the manual it does state that 6” single wall or 6” double wall should pipe be used. It appears that my liner is 5 1/2” rather than 6”. I’m not quite sure what I should do at this point. Any suggestions?
Todd
10,175
NW Wisconsin
Could you just connect the liner directly to the rear stove collar without the tee? Where it comes time to clean just disconnect, tape a plastic bag over the liner and sweep the chimney into the bag. If not there are adapters online, maybe if you purchase one they will install it. A good place to look is Rockford Chimney supply.
How’s the stove working out? I have the same stove and love it.
Reactions: bigealta
EbS-P
5,307
SE North Carolina
Reactions: stovelark
Ctwoodtick
2,061
Southeast CT
Could be a couple things. If the installer is being really diligent, they may have some concerns about connecting a different manufacturer’s component to the installation.
Or perhaps, they’re not interested getting involved in a smaller project like this.
Who knows.
I suppose the option is still there to go back to top exit. Yearly cleaning should be not be very difficult. It’s not like you were dealing with a non functional stove setup before.
EbS-P
5,307
SE North Carolina
Who knows.
Read the manual for the F45. I would never recommend a top vented hearth installation for this stove. Cleaning means that the stove for all intents and purposes must be disconnected from the liner and moved out of the fireplace for cleaning.
Ctwoodtick
2,061
Southeast CT
Will do. I would’ve figured that the top vent cleaning would be a lot easier, like other Jotuls
Reactions: EbS-P
RI_FL_Line
38
Rhode Island
Thanks. I’m sending him this.
Does the installers response make sense?
“No unfortunately this would make 3 different parts from 3 different
manufactures with no guarantee that they would all work together.
We do not like to mix and match different products and sizes
because we do not feel it is safe.”
EbS-P
5,307
SE North Carolina
Paging @bholler and @begreen
RI_FL_Line
38
Rhode Island
I also love the stove.
bholler
Chimney sweep
Staff member
Jan 14, 2014
32,857
central pa
I honestly have never seen a 5.5 tee that didn't have a 6" snout. The guy is full of crap
