I have the latest (I think) version of the BK Ashford 25 insert manual, and I'm confused on the wording on some of the steps:
6. Once the kindling is fully on fire, place two or three medium size logs onto the fire. Keeping the loading
door unlatched, allow the logs to catch fire. DO NOT LEAVE THE STOVE UNATTENDED.
7. Once the logs are burning, latch the loading door shut. Once loading door is closed and combustor
temperature begins to climb, close the bypass door, turn fan(s) on to high (if equipped). Leaving the
loading door open after the wood load has caught fire may cause premature failure of the catalytic
combustor.
8. When nearly all of the wood in the firebox is fully burning and the catalytic thermometer is in the active
zone, open the bypass door and loading door, and finish loading the appliance. Lay the wood as far
back in the stove as possible. Latch the loading door shut, and close the bypass door.
On step 7, my understanding was not to close the bypass door until the guage was in the active zone, and not before. Additionally, if you turn on the fan(s) doesn't that hinder the ability for the firebox to get up to temp?
On step 8, after opening the loading door and adding the primary load, the cat will have dropped out of the active zone, it seems to be requesting the bypass door to be closed again prematurely.
Thoughts?
combustor.
Thoughts?
