As of last night I now know I have made as excellent decision with the Equinox. (This hardly ever happens to me)
The following is a quote taken from another thread here "If I fell behind the curve it was very, very hard to catch back up and I ended up having to burn oil." This was a huge issue for me using my old Duchwest, I would spend hours farting around trying to get the house from 60 to 65 degrees and all the while I would get complaints from the wife and kids. That was frustrating, putting all that work into maintaining a good wood supply and then have to put up with crummy results.
The Equinox to my pleasant surprise produces heat much faster and with much less fuss than the Duchwest. (I should add to this statement, if one was willing to really let the Duchwest blare with the ash door open for a while, heat up times were better but I considered this to be kinda dangerous and the better part of a wood load would be used up in no time at all). I was very concerned about this initial heat up time, but I have found the stove top is warming after just 10 minutes from cold start and based on the collective here this is not what I expected. After 20 minutes we are heating and after that well you get the idea.....
Last night I started a fire with a 12 round x 26" long piece of white birch junk that had been broken in half during logging and was a mass of splinters at one end. I used no kindling, just one match and I had enough fire to build on with regular splits. I moved the indoor temp up 10 degrees in 90 minutes and my stove top never went above 220. It was in the lower 40's outside and yes I checked the stack, no smoke.
So far I am very happy.
