Hi! First post, it'll be a long one.
My current plan: to buy a small, simple, cheap-ish woodstove that will fit on the existing 48" corner hearth pad in my new house, and use it for the next winter or two while we determine exactly how much heat we need. Possibly upgrade to a Woodstock Survival Hybrid or a Woodstock Absolute Steel and sell the original stove.
The long version: so I grew up with a Jotul, but I have never heated a house I owned with a woodstove. We just bought a more rural place where the options are to install a woodstove on an existing corner hearth pad, or use the old propane heater, and the cost of buying wood is at least 3x less than propane per BTU. There's also lots of dead wood on the property, most of it soft but at least some of it is Pinon. We have the tools and knowledge to chop our own wood but may be running a little late to season it properly this year.
The house was built in the 80s, '86 I think. The corner hearth pad that came with the house is in the living room, toward the north end of the house, 48" long sides, about 3" thick field stone on the walls and looks like slate for the pad. I have no reason to believe there's ventilation behind the stone and I'm not sure how I would find out, so I'm treating it like bare walls as far as clearances. There's a 6" (need to measure to confirm) chimney hole in the roof with a metal chimney rising through the roof. The house is 1400 sq ft, and I have realized that any stove rated to heat the full square footage is going to require a larger hearth pad. I will also be building a south-facing passive solar greenhouse with a ventilation system that should add heat to the south end of the house, and should be completed this winter. House is in heating zone 4. So my current plan is to buy a small stove, rated to around 30,000 BTUs, while we figure out exactly how much heat we need and before pouring money into modifying the pad and potentially modifying the stone wall covering (which would be aesthetically weird after we expand the pad). The rest of the heat will be provided by the greenhouse and, when necessary, the propane heater.
Ideally after heating for a winter with a simple stove, we'll have a better idea of what we want including soapstone, catalytic combustion, BTU output, etc. I'm also afraid that if I get a stove that's too big, I'll have to run it really hot to burn clean, and I'll end up with open windows in January.
There's an Atlanta Stoveworks Woodsman available locally for $400, and I found a pdf of the manual on here, but no BTU rating. Would that be a good option? I'm open to other suggestions as well.
![[Hearth.com] Beginner Woodstove Suggestions [Hearth.com] Beginner Woodstove Suggestions](https://www.hearth.com/talk/data/attachments/297/297638-9ff284974a9a8123f25b94d0dead64da.jpg?hash=umwMdTh6KC)
